Er det noen av dere med katalogen som har bilder av hvordan dørsida i en golf 5 er festet?
Kom på at "dørside" kanskje var på innsiden så legger ved det også.
Removal
– Switch off ignition.
– Using a removal wedge -3409-, lever upper part of door handle recess -1- upwards out of mountings in door.
– Depending on vehicle equipment, disconnect wiring harnesses from upper part of door handle recess.
– Remove the two bolts -2- in area of door handle recess (1.5 Nm).
– Remove bolt -3- and the three bolts -4- (2 Nm).
– Using removal pliers -3392-, release bottom section of door trim from mountings.
– Using removal pliers -3392-, release sides of door trim from mountings.
– Pull door trim upwards vertically out of window slot.
– If vehicle is equipped with a radio system, disconnect wiring harness from loudspeaker.
– Disconnect wiring harness of door trim from door control unit.
– Detach Bowden cable -5- from interior door handle mechanism -6-.
– Remove bolt -7- (2 Nm) and lever triangular mirror cover -8- out of fasteners using wedge -3409-.
– If vehicle is equipped with a radio system, disconnect loudspeaker wiring harness from cover.
Pass på å få ALLE skruene tilbake på rett plass. Hvis ikke risikerer du å lage utoverbulker i dørplata fordi skruene har ulike lengder!
