Instrumentholder i CD spiller hullet
Noen som vet hvor jeg kan skaffe instrumentholder i DIN cd spiller format?
Må være til 3 x 52 mm instrumenter.
Sikkert mulig å lage noe selv, men greit å ha noe som ser litt bra ut å.
http://www.tmtuning.com har til 13.95$
This gauge panel fits in the radio DIN slot and is great because it allows you to use up to 3 gauges, or none!
The main feature of this DIN gauge cover plate is the pre-cut gauge spots with removeable cover plates for the gauge holes that are reuseable. The DIN plate itself also simply clips into the DIN space and can be easily removed, it requires no special tools or pieces to install.
This is the ultimtae radio delete panel, fits standard 52 mm diameter instruments.
