Resette serviceindikator på en 95 Golf 3 GTI
Hei!
En kompis av meg har en 95 Golf GTI som det står IN 02 i dasjbordet på.... dette er vel service indikasjon? Hvordan får jeg slettet meldinga? Veit at det kan gjøres med og uten vag com....
Har vag com (.409) kan jeg gjøre det med denne versjonen? Isåfall hvordan? Har også hørt rykter om at det er mulig å holde inn noen knapper i dasjbordet? Hva er oppskriften her?
Blei mye på en gang her : rolleyes
Håper noen gidder å svare meg her ;)
TO RESET THE INDIVIDUAL INDICATOR COUNTERS:
1. Turn on ignition (do not start the car)
2. Press the trip-reset button on the odometer (the trip value will not be reset to zero but will reappear when the procedure is completed)
3. Turn off the ignition and then release the trip-reset button.
In the LCD display, you will see the display "OEL".
Using the button to set the MINUTES (lower one) of the digital clock, you will reset the OEL interval counter. Press it, hold, release. Five (5) horizontal lines will appear in the LCD display.
4. Press and release the trip-reset button
In the LCD display, you will see the display "IN01". Repeate the process under step 3 above to reset this counter when required.
5. Again press the trip-reset and reset the IN02 counter if necessary.
If doing an oil change, ONLY reset the OEL counter.
If doing the IN01 service, reset BOTH the OEL and IN01 counters.
If doing the IN02 service, reset ALL of them, the OEL, IN01 and IN02 counters.
6. Turn on ignition (do not start the car).
7. After the appearance of the "IN00" display, turn off the ignition.
8. You are done. The trip counter should read as it did before you started.
