Ingen som har lagt inn dette før altså ?
VW Polo S2000 WRC
Specification
Engine
Cylinders: four in-line
Fuel supply: sequential fuel injection
Cubic Capacity: 1984 cm3
Valve gear Soupapes: dohc, four valves per cylinder
Ignition: electronic, Bosch MS3.1, with 128MB hidden logging
Fuel requirement
Engine Output
Max Power ISO (kW): 210 Kw (282 Hp)
Power peak: (r/min) 8250
Max usable: (r/min) 8500
Torque Peak: (r/min) 7000
Transmission
Forward speeds: 6
Driven wheels: 4x4
Front differential: Mechanical Limited Slip
Rear differential: Mechanical Limited Slip
Centre differential: Mechanical Limited Slip
Clutch/Ambrayage: AP Racing twin plate
Wheels and Tyres
Gravel Rally wheels: 6.5Jx15 alloy
Tarmac Rally wheels: 8J x 18 alloy
Tyre size gravel: 195/65 R 15
Tyre size Tarmac: 235/40 R 18
Brakes
Front calipers: 300mm ventilated discs with 4-piston Alcon
Rear calipers: 300mm ventilated discs with 4-piston Alcon
Hydraulics: dual circuit with balance bar
Steering
Type: Rack and pinion, power assisted
Lock to Lock: 2 turns
Suspension
Front: MacPherson struts, Reiger dampers, Coil springs, fabricated wishbones, anti-roll bar
Rear: MacPherson struts, Reiger dampers, Coil springs, fabricated wishbones, anti-roll bar
Capacities
Fuel tank: 70 litres
Dimensions
Overall length 3916mm
Overall width 1800mm
Ground clearance 170mm
Wheelbase 2470mm
Track front 1587mm
Track rear 1587mm
Weight
FIA (minimum 1150kg) 1150kg
http://www.renegeorges.be/fr/index.asp?lg=2
http://www.youtube.com/watch?v=9dHRcOTQ3Jc&mode=related&search
Basic Kit ca: 1.500.000 KR
Full Asphalt Specification ca: 2.150.000 KR
Da er bilene klare til bruk :)
Mye bråk og lite fart...
Blir kjedelig når dagens wrc biler forsvinner
Men bilen er rå ja :)
Men det er vel ikke prat om at dagens WRC biler skal forsvinne..Dette er vel bare for å få inn en klasse til som kan være billigere for flere fabrikker ? Sånn jeg har skjønt det iallefall..tror ikke dagens WRC biler vil forsvinne av den grunn..
Super 1600 og Super 2000 er klassene under WRC ja, akkurat som Formel 2 og 3 er under Formel 1. Det er heftig med 282 hk fra en toliters sugemotor! :tilber:
det må jo gå noe så instinihælvete bra!!
å den polen så faktisk veldig bra ut også:D
Det har vært snakk om at WRC skal ut ja. Det koster for mye. Men nå er jo snart S2000 like dyrt.
Er jo snakk om at de skal kunne ha et turbo kit som skal kunne monteres på, da på så kort tid at det går på en service.
Litt rare regler, men er vel for at det skal bli noe simplere og billigere. Men da er vi jo snart oppe på WRC nivå igjen.
--Dette er vel bare for å få inn en klasse til som kan være billigere for flere fabrikker ? Sånn jeg har skjønt det iallefall..
Er det ikke denne klassen som er IRC (International Rally Challenge/Championship) og som allerede er godt igang?
Håper da virkelig ikke dagens WRC biler forsvinner! :)
Heftig polo med en heftig prislapp.
Det der må være den råeste poloen som finnes:D
Her fra Rally Larvik i september
