Passer turbo fra A4 190hk på AEB motor?
Lurer på om k03 turboen fra A4 BEX 190hk passer på en AEB 150hk motor?
K03-005 Er orginalt på AEB
K03-029 blir levert på nyere 1.8t og blir vel også brukt på turbo bytte på AEB.
K03-073? Er vel den som er levert på BEX 190hk
Sien den er muligens litt større så går det uten og mappe på nytt, k04 blir for mye for min stakkars tiptronic
Litt info jeg fant:
These are all
original
core turbos from Audi/VW's. We totally disassemble them, clean them,
inspect them and replace any parts that do not meet new specifications.
Then we rebuild them with the upgraded heavy duty journal bearing, and
sell the with a full warranty. So, they are remanufactured.
Here is the story on the 058 145 703J turbos, these are the turbos that
we
sell on our website, we hope this will answer some questions. The
information we will provide you with below is collected from various
sources and personal experience with these turbos over the years, all
part
# information is directly from the Borg Warner Turbo Systems "Turbo
Driven
interactive hidden system", this stem has been updated to the latest
version
so that all of the information is as current as possible.
The part # for the turbos we sell is 5303 970 0029 and the reference #
is
058 145 703J. These are the used on the Audi A4/A6 1.8T from 1999-01 to
2002-11. These turbos will also replace the turbos on the 1995-02 up to
1998-12. The reference #'s for the older turbos is the same except for
the
last letter 058 145 703, the letters can be C, E, H, L, and K. After
2002-12 the A4/B6 1.8t motor used a different turbo its part # is 5303
988
0073 and the reference # for this turbo is 06B 145 703 B. This turbo
has
the same a slightly larger compressor wheel than the K04-015 turbo and
the
same size turbine wheel. This turbo is probably the biggest reason that
this model makes 190HP instead of the old 150HP version. We would think
that this last turbo listed here is what is call the K03 Sport turbo,
although Borg Warner/KKK do not call it this in any of there
information.
We have checked the part #'s of the internal parts of each of all of
the
above listed turbos. From this point forward we will refer to them as
follows: K04-015, K03-029, and the K03-073 (or the K03 Sport). We will
list the internal parts that are the same first, then the differences
below that. These are the parts that are the same on all 3 turbos,
bearing
housing, retaining rings, locking clip, turbine shaft and wheel
assembly,
compressor end piston ring, thrust ring, thrust ring, flinger sleeve,
turbine end piston ring, oil deflector shield, compressor o-ring, shaft
nut, clamp plates, and the heat shield.
These are the parts that are different, journal bearing, compressor
wheels, backing plates and compressor housings, turbine housings, and
actuator/adjustment.
Additionally, the turbine housing on the k03-029 and the k03-073 is the
same. Also, the compressor wheel for the K03-073 is actually a little
larger than the K04-015 turbo and uses Borg Warner's extended tip
technology. This makes the wheel more efficient, and have a wider map.
The
fins are longer, and more curved than the K04-015 compressor wheel.
When we upgrade the K03-029 turbo we upgrade the compressor wheel,
backing
plate and the compressor housing is bored to K04 specifications. We
also
use the heavy duty journal bearing from the K04 in our turbo rebuilds.
The
last thing we modify in our turbos is the wastegate adjustment to match
the K04-015 setting. This leaves the only part that is not the same or
better than the K04-015 spec is the turbine housing, from all of our
measurements they seem to be the same, and to perform the same.
We hope this has cleared up some of the confusion of these turbos and
there upgrades, we know that there will be more questions, ask them at
any
time. Thank you,
Turboen burde passe. Er vel samme utvendige mål, men med forskjellig actuator, og litt forskjell på turbinbladene
