#1 Skrevet Januar 22, 2009 Hei koblet opp bilen til vag-com i dag og fikk opp denne feilkoden 16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow. Noen som kan tyde den for meg. Bilen det gjelder er 2004mod a4 190hk. Mvh.Stian 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#2 Skrevet Januar 22, 2009 16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow Possible Symptoms Malfunction Indicator Light (MIL) active Possible Causes Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed Evaporative Emission (EVAP) Canister Sealing faulty Pipes between Tank Breathing and Throttle Body leaky/blocked Possible Solutions Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) Perform Output Test Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) Check Evaporative Emission (EVAP) Canister Perform Basic Setting Check Pipes between Tank Breathing and Throttle Body Retrieved from "http://wiki.ross-tech.com/index.php/16825/P0441/001089" 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
