elektrisk feil 07 s3 reinsensor lys sensor
sliter med feilmelding på regnsensor og lyssensor får dette på vag-com:
Address 09: Cent. Elect.
Control Module Part Number: 8P0 907 279 F
Component and/or Version: Bordnetz-SG H43 1201
Software Coding: ED8E5F078014100000000000000000000008EE175A0500
Work Shop Code: WSC 06314
Additional Info: Fehler Lin-Slave 01 Fehler Lin-Slave 02
5 Faults Found:
02071 - Local Databus
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 15
Mileage: 27608 km
Time Indication: 0
Date: 2009.06.29
Time: 11:45:00
Freeze Frame:
ON
Voltage: 13.80 V
ON
ON
OFF
OFF
OFF
01500 - Bulb for Fog-Lamps; Right (L23)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 53
Mileage: 27578 km
Time Indication: 0
Date: 2009.06.28
Time: 20:05:00
Freeze Frame:
ON
Voltage: 14.00 V
ON
ON
OFF
OFF
OFF
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 15
Mileage: 27608 km
Time Indication: 0
Date: 2009.06.29
Time: 11:45:00
Freeze Frame:
ON
Voltage: 13.80 V
ON
ON
OFF
OFF
OFF
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 5
Reset counter: 55
Mileage: 27637 km
Time Indication: 0
Date: 2009.06.29
Time: 13:08:00
Freeze Frame:
ON
Voltage: 13.80 V
ON
ON
OFF
OFF
OFF
00153 - Windshield Wiper Motor; Driver Side (V216)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 15
Mileage: 27608 km
Time Indication: 0
Date: 2009.06.29
Time: 11:45:00
Freeze Frame:
ON
Voltage: 13.80 V
ON
ON
OFF
OFF
OFF
noen med noe ideer om hvor å begynne å leite??
