Har en A4 B5 1.8
Har endel feilkoder..
17733 - Knock Control: Cylinder 1: Regulation Limit exceeded
P1325 -35-10 - - - Intermittent
17734 - får ikke mere info pga shareware versjon
00561 - Får ikke mere info pga shareware
16711 - knock sensor 1 (g61): signal to low
16486 - får ikke mere pga shareware...
Noen tips? :)
Fant disse på Ross-Tech Wiki. http://wiki.ross-tech.com/index.php?title=Category:Fault_Codes&until=01537
17733 og 17734 sto ikke listet opp.
00561 - Mixture Adaptation
00561 - Mixture Adaptation: Adaptation Limit (Add) Exceeded
Possible Symptoms
Engine Jolting
Increased Fuel Consumption
Poor Idling/Jolting
Reduced Boost Pressure
Possible Causes
Mass Air Flow Sensor (G70) faulty
Fuel Pressure too Low
Leaks in Intake Air System and/or Exhaust System
Injector(s) faulty (i.e. coked)
Possible Solutions
Refuel Vehicle
Check Fuel System Pressure
Check Mass Air Flow Sensor (G70)
Check Intake Air System and Exhaust System for Leaks
Check Injection Quantity
Check Injector(s)
16711/P0327 - Knock Sensor 1 (G61): Signal Too Low
Possible Symptoms
Irregular rpm
Drivebility problems
Loss of power
Engine damage
Possible Causes
Circuit G61 short to Ground
Circuit G61 open
G61 loose
G61 damaged
Control Module damaged
Possible Solutions
Tighten Knock Sensor 1 (G61)
Check wiring and connections
Check Knock Sensor 1 (G61) and Knock Control
Special Notes
This feature search for unusual (spontaneous) combustion. The sensor detects unusual vibrations and based on that it generates a voltage. Is this voltage outside a certain limit a dtc will be set.
16486/P0102/000258 - Mass Air Flow (MAF) (G70): Signal too Low
Possible Symptoms
Probably no serious malfunctions
Loss of power
Possible Causes
Wiring and/or connections (short circuit?)
Mass Air Flow (MAF) (G70) defective
Possible Solutions
Check / Replace Mass Air Flow (MAF) (G70)
Special Notes
In MY 1995-2002 (?) in Europe at VW-diesel-cars G70 had the bad reputation of slowly losing his performance, causing loss of power. It's not a matter of defective or breaking down, but it is filthy / dirty (not easy to clean). You can check functionality by making a log in [01-engine], [meas.blocks-08], group 003 (3e gear, full throttle, from 1700-4000rpm)
kan også nevne at av og til så vil ikke bilen starte på første forsøket, men starter altid på andre :)
