#1 Skrevet Juli 30, 2010 (endret) Har en kamerat som har en 1.8 som stopper når den er blitt varm,må vente 10min før den starter igjen. Klarte å holde den igang over 4000 o/min men stopper under.. Har ikke fått lest av feilmeldinger,men noen som har en ide hva det kan være? 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#2 Skrevet August 1, 2010 Feikoder. Sunday,01,August,2010,14:27:07:59303 VAG-COM Version: Release 704.1 Address 01: Engine Control Module Part Number: 8D0 906 018 AD Component and/or Version: 1.8L R4/5V MOTR 0002 Software Coding: 05032 Work Shop Code: WSC 00011 Additional Info: WAUZZZ4BZ1N063150 AUZ5Z0Y9065029 2 Faults Found: 17646 - Fuel Injector for Cylinder 2 (N31): Open Circuit P1238 - 35-10 - - - Intermittent 16706 - Engine Speed Sensor (G28): No Signal P0322 - 35-10 - - - Intermittent Readiness: 0000 0000 VAG-COM Version: Release 704.1 Data version: 20070422 Sunday,01,August,2010,14:37:24:59303 Chassis Type: 8D - Audi A4 B5 Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77 VIN: WAUZZZ4BZ1N063150 Mileage: 165690km/102954miles ------------------------------------------------------------------------------- Address 01: Engine Labels: None Part No: 8D0 906 018 AD Component: 1.8L R4/5V MOTR 0002 Coding: 05032 Shop #: WSC 00011 WAUZZZ4BZ1N063150 AUZ5Z0Y9065029 No fault code found. Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: None Part No: 01N 927 733 ED Component: AG4 Getriebe 01N 4533 Coding: 00000 Shop #: WSC 00000 5 Faults Found: 00777 - Accelerator Position Sensor (G79) 27-10 - Implausible Signal - Intermittent 00660 - Kickdown Switch or Throttle Position Sensor 27-10 - Implausible Signal - Intermittent 00529 - Engine Speed Signal Missing 35-10 - - - Intermittent 00545 - Engine-Transmission Electrical Connection 31-10 - Open or Short to Ground - Intermittent 01314 - Engine Control Module 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: None Part No: 8E0 614 111 B Component: ABS/EDS 5.3 FRONT D10 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4B0-820-043-MY1.LBL Part No: 4B0 820 043 K Component: A6-Klimavollautomat D64 Coding: 00040 Shop #: WSC 02325 1 Fault Found: 00779 - Outside Air Temp Sensor (G17) 30-10 - Open or Short to Plus - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4B0-959-655-AI8.LBL Part No: 4B0 959 655 G Component: Airbag Front+Seite 1001 Coding: 00106 Shop #: WSC 02325 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4B0-920-xxx-17.LBL Part No: 4B0 920 900 K Component: KOMBI+WEGFAHRS. M73 D56 Coding: 00042 Shop #: WSC 00390 WAUZZZ4BZ1N063150 AUZ5Z0Y9065029 No fault code found. 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#3 Skrevet August 1, 2010 Har slettet feilkoder og det g28 som dukker oppigjen,virker som det stopper naar bilen blir varm,kan denne foleren slutte [ fungere p.g.a varmen 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#4 Skrevet August 1, 2010 Min G28 sensor feila stadig mer i varmt vær og når motoren gikk seg skikkelig varm, så det kan stemme fint. Rimelig grei å bytte denne, bare så synd den koster en del... 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
