Luftproblemer Audi A6 C5-1999 stv
Har en bil som "ligger " helt på ræven.
Ingen sikring er gåen i følge eier. Hvor skal eg starte feilsøking?
Har scannet med VAGCOM, og skal lese meg opp på denne seinere (ligger på en annen pc, derfor ikke tilgang på hvilken feilmelding som låg inne)
Noen som har erfaringer å dele, setter eg pris på dette:-)
Monday,27,September,2010,11:58:22:56833
VCDS Version: Release 10.6.1
Data version: 20100831
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
Mileage: 229650km/142697miles
Address 01: Engine Labels: Redir Fail!
Part No: 038 906 018 FN
Component: 1,9l R4 EDC G000AG 2161
Coding: 00004
Shop #: WSC 23352
VCID: 67D64AE82F1F
2 Faults Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
17958 - Charge Pressure: Control Deviation
P1550 - 35-10 - - - Intermittent
Readiness: N/A
Address 02: Auto Trans Labels: None
Part No: 01N 927 733 EB
Component: AG4 Getriebe 01N 4420
Coding: 00000
Shop #: WSC 00000
VCID: 75EA10A065B3
No fault code found.
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389
Component: ABS/ESP front D05
Coding: 06257
Shop #: WSC 02325
VCID: F0E4A1B49AD1
Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
Part No: 4B0 959 655 G
Component: Airbag Front+Seite 0001
Coding: 00106
Shop #: WSC 02335
VCID: 346CEDA42E49
1 Fault Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
Address 17: Instruments Labels: 4B0-919-xxx-17.lbl
Part No: 4B0 919 881
Component: C5-KOMBIINSTR. VDO D15
Coding: 21040
Shop #: WSC 71188
VCID: EAD0B3DCBC0D
Part No: IMMO
Component: IDENTNR: AUZ7Z0X0946822
IMMO-IDENTNR: AUZ7Z0X0946822
Address 34: Level Control Labels: None
Part No: 4B0 907 553
Component: Niveauregelung x013
VCID: E3CEDEF85B27
1 Fault Found:
01400 - Suspension Level Control
08-10 - Control Limit Surpassed - Intermittent
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 D
Component: Zentralverriegelung D32
Coding: 04673
Shop #: WSC 02335
VCID: 2A50F3DCFC8D
5 Faults Found:
01570 - Turn-Off Delay; Terminal 15
29-10 - Short to Ground - Intermittent
01559 - Drivers Door
59-00 - Can't Unlock
01561 - Left Rear Door
61-00 - Won't De-Safe
Address 37: Navigation Labels: Redir Fail!
Part No: 4B0 035 192 E
Component: Navigation 0004
Coding: 00000
Shop #: WSC 02335
VCID: 1F461208B7CF
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
36-00 - Open Circuit
Address 56: Radio Labels: Redir Fail!
Component: Radio 0004
Coding: 00207
Shop #: WSC 02335
VCID: 1F461208B7CF
2 Faults Found:
00856 - Radio Antenna
00852 - Loudspeaker(s); Front
36-10 - Open Circuit - Intermittent
Address 76: Park Assist Labels: 4B0-919-283.lbl
Part No: 4B0 919 283
Component: Parkingsystem A6 RDW D18
Coding: 01106
Shop #: WSC 02335
VCID: E6C8C7ECA815
End ---------------------------------------------------------------------
Var vist litt forskjellig å ta tak i her:-)
