#1 Skrevet Februar 2, 2012 (endret) Time to take back my garage so here's a few things that have been hiding on the shelves. Prices on everything but open to offers. All plus post. Innovate Motorsports wideband air/fuel ratio meter. Its the basic model and does nothing more than let you know your not running lean or rich. You can log to it and read the results on your PC. Great item if you are setting up carbs. Comes with the lambda sensor and all the wiring needed to fit it. I used it for maybe a month while I set up a K-jet system. No instructions but I guess you can find info on line. 500kr plus post SOLD New Mk1/Mk2 Golf (prob others) Carb throttle cable. Brand new never fitted. 300kr plus post Engine parts. Will fit most early VW engines. The main bearings are standard. The thrust bearings are ONE SIZE UP. There are only 7 valve seals and one valve guide. The bearing are quality victor reinz as are the seals. The valve guide is genuine VW. 400kr plus post Set of EV code pistons. From a mk2 golf gti 8v. They are standard size and look to be in V good condition. Will come with the pins. 300kr plus post Carbs. 1x 32/36 DGAV Carb. Originally fitted to fords fast escorts Pinto's etc.... No clue what the set-up is or if its 100% complete. All the linkages move freely. 300kr plus post I also have 2 nice alloy filter covers. They are solid alloy and not the more modern plated tin. 400kr plus post (for both) Carb. Another weber twin choke. I've no clue what is from but the code is DCNV. Good condition. 300kr plus post. Box with spares diaphams, joints, etc Take the lot for 750kr More.... head gasket. The plastic has been opened but the gasket is in prefect condition. 250kr plus post Mk1 Golf front rollbar bushes. Not often you see these as they don't come in the standard kits. They are made by 'superpro' so are quality. 350kr plus post SOLD and lastly ....for now anyway, an alloy valve cover. Originally from Mk3 gti golf and any other vw with the 2E engine. Polished but needs a good clean. 350kr plus post.SOLD PM me if your interested Steve 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#2 Skrevet Februar 2, 2012 Hi I take the Innovate Motorsports wideband air/fuel ratio meter 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#3 Skrevet Februar 3, 2012 brand new mechanical fuel pump. This is for carb engines and comes with the mounting spacer and a nearly new competion high flow fuel filter.... think its cleanable but not 100% sure 350kr plus post. Steve 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#4 Skrevet Februar 13, 2012 To the top.... 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#5 Skrevet Februar 22, 2012 one more time.... open to offers remember S 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#6 Skrevet Februar 25, 2012 350 ink. post for the valvecover? Same accountnumber as last time;)? 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#7 Skrevet Februar 27, 2012 350 ink. post for the valvecover? Same accountnumber as last time;)? Yep that sounds good . Same account as last time but please PM me your address. Steve 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
