Passaten stopper en til to ganger i uken.
Arm motor
Kan feil kode på Lambda forårsake feil nr to på Throttle Position Actuator?
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 3B0 907 557 P
Component and/or Version: 1,6l R4/2V SIMOS HS D04
Software Coding: 04021
Work Shop Code: WSC 05311
VCID: 3669D279125C5D9
2 Faults Found:
00537 - Lambda (Oxygen Sensor) Regulation
18-10 - Upper Limit - Intermittent
00282 - Throttle Position Actuator (V60)
44-10 - Short Circuit - Intermittent
