034Motorsport Wheel & Nut Kit ! ( M14x1,5 - 56mm )
Sakser over beskrivelse fra 034Motorsport :
" Wheel nut and stud combo, M14x1.5 threads, Grade 8.8 with Zinc plating.
Wrench head size of 19mm or 3/4", up from 17mm OEM size.
3" are recommended for any spacer up to 25mm, but also for race cars where longer studs allow faster wheel changes and options for virtually any spacer configuration.
Fits all Audi application with M14 threaded hubs, cone seat for most aftermarket wheels, Ball seats for OEM wheels. Take note, don't be fooled by companies offering Porsche Ball nuts, they have a much wider diameter seat that does not fit correctly in VW/Audi wheels and essentially damages the seating surface.
For 3.0" Stud, lower threads are .46" (12mm) long, upper threads are 2.2" (56mm) long"
Settet er NYTT og ubrukt, alt ligger i orginale poser.
Koster 79 USD + Frakt ( 79 USD ) nytt fra 034 = 958kr etter dagens kurs.
Selges : 800Kr inkl. frakt
Ta kontakt på 99012942, pr.PM eller på epost : andersth86@msn.com
Penger overført :)
Solgt til Roy : vinke :
