Torsen senterdiff med 4:1 bias fra a4 1.8t 01a Quattro girkasse - 1500,-
Selger en senterdiffen som passer 1.8tQ girkasse med "Washer Mod".
Det vil si at en skive settes inn istede for et nålelager som sitter der. Dette gjør at det blir mere friksjon som igjen vil gi mere trekk bak ved slipp foran (org Bias 2:1 vs. 4:1 med skive)
Pre. facelift diff. Passer på facelift også men da må huset også byttes (kommer montert i dette, bare ikke med på bilde).
Kan lese mer om det her og her.
Dette er den samme modden som 034Motorsport og STaSIS gjør for $550!
Torsen Center Differential Upgrade
Tuning the center differential provides one of the most significant performance gains available to the Quattro owner. The standard torsen center differential in the S4 and A4 provides a 2:1 torque distribution capability. This enables the end of the car with traction (generally the rear) to deliver twice the torque being delivered by the least tractive end of the vehicle (generally the front).
The STaSIS high bias torsen provides a dramatic improvement in negotiating a turn quickly and efficiently. Now your car can be 3 cars in one( front, all and rear wheel drive):
Hard Braking, Leading Into A Turn
Car acts like a front wheel drive – torsen acts like an open differential when its not under power. Wheels turn independently and car control is improved.
Mid Corner, Throttle On
Car acts like an all wheel drive – torsen delivers equal amounts of power to front and rear wheels. This maximizes grip, allowing more power to be applied at this stage of a turn.
Corner Exit, Hard Acceleration
Car acts like a rear wheel drive car – front wheel slip is reduced because the torsen delivers up to 88% of the engine torque to the rear wheels where the most traction is.
Hva slags hus må man bytte til om man har facelift modell?
Det bakre her som sitter i 7(?) skruer. De passer overens. Det går bare ikke å ha facelift diff og prefacelift hus f.eks.
Men huset føger med så denne skal gå på begge.
Åssen blir denne på en a4 b5 stasjonsvogn?
edit..
Jeg tar den jeg :)
Petter, skulle du ha denne?
Hvis ikke; BUMP :)
Lagt til etter 5 dager 21 timer:
Kan ta med denne til Våler i helga. Men da må jeg vite det før kl 18!
noen aning om det er forskjellig diff på tiptronic kassa?
Har ikke peiling dessverre..
Hmm, er inntresert om det passer, men må nesten finne ut det først :)
Byr 1000,-
Mvh Kim Rune
