#1 Skrevet April 29, 2005 Hørte av noen kompiser at det gikk ann å sjekke tilstanden på g-laderen ved å trykke en "spesiell kode" på kjørekomputeren sammen med tenningslåsen. Noen som vet noe om dette ? 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#2 Skrevet April 29, 2005 Check mode test verifies MFI is operating with the correct base vehicle information a. set MFI memory switch to position 1 b. switch ignition ON c. press and hold MFI select button d. switch ignition OFF, then back ON e. release mode select button (engine MAP code is displayed) f. press and release mode select button to advance to next mode (country code should be displayed) g. continue pressing and releasing mode select button to advance sequentially from mode to mode. > According to my Bently book, the info given in "Check mode test functions" (MFA switch to position 1, ignition on, press and hold mode select button in, ignition off, then back on) is as follow (up to August, 1990, pp 91.10-91.11): 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#3 Skrevet April 29, 2005 Function Times mode pressed Mode Indicated Value displayed Engine Map code 0 -- 018Country code 1 clock 4 (USA) 1 (Canada)Speedo drive ratio 2 mpg or L/100km 955 (USA) 950 (Canada)Upper rpm limit 3 miles or km 7418Lower rpm limit 4 mph or km/h 1175Decelleration fuel shut-off pressure(mbar) 5 oil temp. 57Segment test 6 -- all segments on For "Measuring mode test functions" (switch on "2", same setup): Function Times mode pressed Mode/symbol inciated Test sum of programmed bytes 0 --Intake manifold vacum (mbar) 1 clockEngine rpm 2 mph or km/hMomentary fuel consuption 3 mpg or L/100 kmSignal from speed sensor 4 miles or kmOil temperature (degrees F or C) 5 oil tempAmbient(outside) temp (degrees F or C) 6 air temp 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#4 Skrevet April 29, 2005 Forekommer vel også 2-3 forskjellige skalaer når det gjelder ladetrykk. Sett litt forskjellig etter modell etc. MFA Readout Motometer/mbar in. Hg 15 200 23.7 55 400 17.890 90 600 11.9 127 800 5.9 148 1000 0 172 1200 2.9 psi 192 1400 5.8 psi 211 1600 8.7 psi 228 1800 11.6 psi 242 2000 14.5 psi 255 2200 17.4 psi Bør med std laderhjul vise minst 211/1600. 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#5 Skrevet April 29, 2005 Hørte av noen kompiser at det gikk ann å sjekke tilstanden på g-laderen ved å trykke en "spesiell kode" på kjørekomputeren sammen med tenningslåsen. Noen som vet noe om dette ? Liker dårlig at du har stjålet avataren min altså..... 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
