4 brukte spredere til salgs for 500kr + shipping.
Vært i bilen min i 7mnd. Funker perfekt.
Dysene har EV1 contakter så ingen adapter behøves + høy ohm så ingen resistor behøves heller.
These injectors are an extremely popular set for use in many imports, up to approximately 125whp per cylinder. One extremely common use of these is with VW / Audi 1.8t Engines wishing to run the common, and excellent Unitronics 630cc injector file. They are an exceptionally high quality injector that works well even with extremely high fuel pressures, and feature a wide angle spray pattern and very good atomization.
Features
High Impedence
Wide Angle spray pattern for multivalve heads!
High quality Siemens Deka Injector works good even with high pressure
Excellent for 1.8t 20v Engines
The injector of choice for the famous Unitronics 630cc 1.8t Big turbo file
Flows 60lb/hr or 630cc / min @ 43.5psi fuel pressure.
