#1 Skrevet November 25, 2012 Hei, godtfolk Jeg har en pakke med sub og forsterker liggende som selges. Dette systemet gir en vanvittig flott lyd og god punch!!! Subwoofer: Nypris 2499,- Info: Enclosed Subwoofer System with Single 12W0v2-4 Subwoofer Driver, Dark Gray Carpet (300 W, 4 O) - Ported Enclosure This powerful slot-ported BassWedge™ subwoofer system delivers awesome output and unsurpassed value. The slot-port runs along the bottom of the enclosure and fires on the same plane as the woofer to produce excellent extension and response smoothness. The port mouth is flared to minimize air-flow noises. The ultra-versatile BassWedge™ shape has extended sides so that it can be placed with the woofer firing out or straight down, off the floor of the vehicle. The shape works equally well in forward or rear-firing installations. This gives you plenty of options for tweaking the loading of the enclosure into your vehicle. This subwoofer system is shipped wired, loaded and ready to connect via a push-button terminal. Finish: Dark gray, high-grade automotive carpet with "JL AUDIO" embroidery on the top edge and "Slot-Ported BassWedge™" embroidered on the port mouth. Construction: MDF Recommended amplifier power: 75 - 300W Nominal Impedance: 4 Ohm 12" Single 4 Ohm W0v3 Series Subwoofer Power Handling: Peak: 600 watts RMS: 300 watts Impedance: 4 Ohm Mineral-filled, polypropylene cone woofer for excellent durability Large roll surround for generous amounts of excursion Elevated frame cooling brings air directly to the voice coil Designed for compact sealed enclosures or medium-sized ported enclosures Large excursion for louder bass and less distortion DMA Optimized motor system reduces distortion and tight, clean bass Lead wire woven into spider for added strength Metallic silver frame finish 2" High temperature voice coil Sensitivity: 85.64 dB Xmax: 11.4 mm 5-1/16" Magnet diameter Mounting Depth: 5-7/16" Cutout Diameter: 11-1/16" Forsterker: Nypris: 2595,- Info: Rockford Fosgate Bilforsterker 2x200W Enten du ønsker å kjøre høyfrekvent komponent høyttalere eller lav frekvens subwoofere, er P400-2 har styrken og fleksibiliteten du trenger for å sette noen alvorlige Punch i kjøretøyet. Kraften fra en så liten forsterker betyr at den er en god match for en 2-ohm DVC subwoofer eller to 8-ohm SVC subwoofere. *12dB/oktav delefilter *25mm strøm/jord terminaler *Kraftige høytaler terminaler tilkoblinger *Subsonisk filter *MOSFET utgangstrinn *MOSFET strømforsyning *RCA gjennomgang *LED indikator på toppen Spesifikasjoner: *Effekt RMS ved 4 Ohm 100Watt x2 *Effekt RMS ved 2 Ohm 200Watt x2 *Effekt RMS ved 4 Ohm Watt brokoblet *Brokobling mulig *Effektivitet 4ohm 70% *Effektivitet 2ohm 65% *Delefilter *Lav-Pass (LP): 50-500Hz 12dB/oktav Butterworth *Høy-Pass (LP): 50-500Hz 12dB/oktav Butterworth *Tonekontroll *Punch EQ2 Bass: 0dB to +18dB @ 45Hz og/eller *Punch EQ2 Diskant: 0dB to +12dB @ 12kHz *Funksjon avhengierp på LP/AP/HP bryter posisjon *Signal inn Lavnivå 1 RCA par *Signal ut Lavnivå 1 RCA par *Fjernkontroll Mulig med PEQ fjenkontroll Punch EQ (Overstyrer innebygget Punch EQ2) *Frekrens respons 20Hz til 20kHz +/- 1,0dB *Dimensjoner (HxBxD) 5,7 x 19,4 x 26,0 cm *Vekt 3,3kg Dette kan bli ditt for en samlet sum av 3000,- Dette systemet er kun brukt noen mndr så dette er billig!! for mer info eller kjøp, send mail på groet78@hotmail.com 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#2 Skrevet Desember 17, 2012 NY PRIS!! Satt ned til 2000,- Førstemann til mølla 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
