Bahnbrenner VR6 12V CNC maskinert fuelrail selges.
VW Mk3 VR6 12v Fuel Rail. CNC machined billet made in the USA by BBM. *Lifetime warranty. This fuel rail bolts right in as a direct replacement of the inferior and restrictive factory fuel rail. Running a turbo or supercharger, the Larger passages increase fuel flow capacity. Aluminum body construction helps to keep the fuel cooler aiding in the prevention of detonation and increasing fuel system performance. Solid billet aluminum construction with O-ring port seals ensures leak free performance even under increased fuel pressure conditions. Brackets are laser cut and brake formed from stainless steel. A perfect fit and lasting quality every time. AN6 In/out.
KUN RAIL og feste braketter. Ingen fittings.
500,- pluss frakt
97681743
