#1 Skrevet Februar 23, 2013 Hei Har kjøpt en bil hvor det er noen småfeil som må fikses. 3 lamper som lyser i dashbordet og følgende feilkoder kom opp: Saturday,23,February,2013,17:52:11:03047 VCDS Version: Release 11.11.5 (x64) Data version: 20121222 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 3B - VW Passat B5 Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77 VIN: WVWZZZ3BZ1E242534 Mileage: 128340km/79746miles ------------------------------------------------------------------------------- Address 01: Engine Labels: None Part No: 06B 906 033 J Component: 2.0L/2V SIMOS32G00HS3826 Coding: 00131 Shop #: WSC 00040 VCID: 275D45ECC5E6F320406 WVWZZZ3BZ1E242534 VWZ7Z0A3559343 1 Fault Found: 16726 - Camshaft Position Sensor (G40) P0342 - 35-00 - Signal too Low Readiness: 0010 1101 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8D0-907-389.lbl Part No: 8D0 907 389 E Component: ABS/ESP allrad D56 Coding: 04275 Shop #: WSC 05311 VCID: 35619FA40F4A91B0C2A 2 Faults Found: 18256 - Please check DTC Memory of Engine Controller P1848 - 35-00 - 18265 - Load Signal P1857 - 35-00 - Error Message from ECU ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 3Bx-907-044.lbl Part No: 3B1 907 044 J Component: CLIMATRONIC B5GP 0002 Coding: 17000 Shop #: WSC 05311 VCID: 285F46D0C8F8FC5849C No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl Part No: 6Q0 909 605 B Component: 0A AIRBAG VW5 04 0006 Coding: 12353 Shop #: WSC 05311 VCID: 366398A8124C9AA8CB0 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 3B0-920-xx5-17.lbl Part No: 3B0 920 825 Component: KOMBI+WEGFAHRSP VDO V13 Coding: 05115 Shop #: WSC 00040 VCID: DFCD9D0C5D36FBE0F86 WVWZZZ3BZ1E242534 VWZ7Z0A3559343 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl Part No: 6N0 909 901 Component: Gateway KCAN 0001 Coding: 00006 Shop #: WSC 05314 VCID: F0EFEEB0B0A8749851C No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1C0-959-799.lbl Part No: 1C0 959 799 B Component: 0J Komfortgerát HLO 0002 Coding: 00259 Shop #: WSC 05311 VCID: 366398A8124C9AA8CB0 Subsystem 1 - Part No: 1C1959801 Component: 0J Tõrsteuer.FS 0001 Subsystem 2 - Part No: 1C1959802 Component: 0J Tõrsteuer.BF 0001 Subsystem 3 - Part No: 1C0959811 Component: 0J Tõrsteuer.HL 0001 Subsystem 4 - Part No: 1C0959812 Component: 0J Tõrsteuer.HR 0001 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4Z7-907-357.lbl Part No: 4Z7 907 357 Component: dynamische LWR D05 Coding: 00008 Shop #: WSC 05311 VCID: 040732601410F838054 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 1J0-035-15x-56.lbl Part No: 1J0 035 152 F Component: Radio BNO 0005 Coding: 00003 Shop #: WSC 05311 VCID: 21495BF4ABC20D100E2 No fault code found. End --------------------------------------------------------------------- Takker for svar 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
