Zotac GeForce GTX 480 1536GB AMP! Skjermkort til PC
Spec:
Core Clock
756 MHz
Memory Clock
950 / 3800 MHz (Clock Rate / Effective Rate)
Shader Clock
1512 MHz
CUDA Cores
480
Total Memory
1536 MB GDDR5
Memory Interface
384 bit
Memory Bandwidth
182.4 GB/s
Output Connectors
1 x Mini-HDMI, 2 x Dual Link DVI-I connectors
Bus Type
PCI-E 2.0
Form Factor
Triple Slot
Accessories
Mini HDMI to HDMI Adapter
DVI to VGA Adapter
Dual 6-pin PCIe to 8-pin PCIe Power Adapter
Dual Molex to 6-pin PCIe Power Adapter
Supersonic Sled / Design Garage Tech Demo
Driver Disk
Zotac Software Bundle
User Guide
Power Requirements 1 x 6 pin , 1 x 8 pin PCI-E power connectors
Minimum 600 Watt power supply
Dimensions
Height - 4.376 in / 111.15 mm
Length - 10.5 in / 266.7 mm
Weight - 3 lbs
Warranty
Limited Lifetime
Selges 1200,- + frakt
Link til finn: http://www.finn.no/finn/torget/tilsalgs/annonse?finnkode=40357778
