4 Kanal forsterker Monacor Carpower NY HPB-604 - 4x75W RMS @ 4ohm
Rydder hjemme og har BOSE i bilen så alt av bilstereo skal selges unna.
1200kr som kan diskuteres ved hurtig handel
th_2013-11-25124248_zps293c1388.jpg th_2013-11-25124258_zps3f767a8b.jpg th_2013-11-25124307_zps7879921b.jpg th_2013-11-25124321_zps4a7f04d0.jpg
HPB-604
Number: 14.2490
Output power
Max. power 700 WMAX
RMS power 1 Ω
RMS power 2 Ω 4 x 100 WRMS
RMS power 4 Ω 4 x 75 WRMS
Bridged power 4 Ω 2 x 200 WRMS
General information
Frequency range 20-20,000 Hz
Load impedance (min.) 2 Ω (bridged: 4 Ω)
Input sensitivity (line) 0.4-4 V/20 kΩ
Input sensitivity (high) -
Channel separation > 45 dB
S/N ratio > 93 dB (A)
THD
Filters
Low-pass 40-300 Hz, 6 dB/oct.
High-pass 40-500 Hz, 6 dB/oct.
Band-pass -
Subsonic -
Equalizer
High EQ -
Low EQ -
Bass boost 0-12 dB/50 Hz
(adjustable)
Power supply
Operating voltage 10-16 VDC current/50 A
Connections screw terminals
Inputs
Line 2 x RCA L/R
High input -
Outputs
Speakers screw terminals
Line 1 x RCA L/R
Remote control -
Admiss. ambient temp. 0-40 °C
Dimensions 252x62x400 mm
Weight 3.3 kg
Other features -
Opp! :)
Kom med prisforslag via PM.
