Nye bosch green giants dyser selges 440cc@3bar
Selger helt nye Bosch Green Giant dyser.
Disse fløder 440cc@3bar
Utstyrt med EV1 kontakt, passer derfor bolt on på de fleste eldre biler som turbokonverteres eller trimmes.
Temmelig kjente dyser dette her, brukes også med høyere railtrykk så disse fløder mer. Opp mot 500cc.
Passer perfekt til trimmede motorer som kjøres hardt.
Pris - 500kr stk
Selges som sett fra 4 og opp over.
Har fler på lager.
Bosch nr: 0 280 155 968
Info om dysene på engelsk er lakt til under:
Genuine Bosch Green Giant 42lb/hour Fuel Injectors
These superb Bosch injectors gained notoriety for their excellent flow and response characteristics in modern Volvo turbo applications. The characteristics necessary to meet stringent European emissions laws while supplying a wide dynamic flow range produces and excellent, balanced injector. The result was so popular in the aftermarket, it was nicknamed the "Green Giant" Injector.
These injectors flow 43 lbs/hr at 43.5 PSI ( 3 BAR ) and much more at higher BAR! In addition, these units are high-impedance. Despite the high flow rate, they are linear and controllable at low pulse widths. This allows you to use a larger injector than normally possible without hurting idle and low speed driveability. Adding to the flexibility of application, these units are high-impedance; making them compatible with most ECUs, while delivering the most flow available in a High-Impedance injector. These injectors represent the most current Bosch engineering and are used on many high power turbo oem applications.
These injectors are able to function at high fuel pressures and don¿t exhibit the high fuel pressure handling problems found with many other high flow high-impedance injectors. This makes these injectors very well suited to turbocharged and supercharged applications that see high fuel system pressures and in fact, that is exactly what they were designed for!
Engine performance and running quality are enhanced through the optimized spray pattern. Unlike competitors «pencil stream» high flow injectors; these High Flow injectors utilize a split / wide cone spray pattern for improved mixture preparation and atomization. This results in lower BSFC and better idle quality than many injectors with less flow.
Features:
Genuine, reliable Bosch Injectors
Excellent response characteristics
Robust Design
High Impedance
Low Impedance performance characteristics with High Impedance Compatibility
Specifications:
Coil Resistance: 12 Ohms (This high-impedance injector will work with all factory ECM/PCM injector drivers)
Spray Pattern: Dual Spray Wide Cone / Split Cone
Electrical Connector: EV1
Fitted with Viton upper and lower o-rings.
Static Flow Rate @ 43.5PSI (300kPa): 42 lb/hr
Applications:
Volvo & many European makes, Audi, BMW, Volkswagen.
Many Japanese makes, Nissan, Toyota, Honda etc.
Made for high pressure, harsh environment turbo & supercharged applications!
Bolt-on dyser til Nissan 200sx S13 CA18DET.
