Feilkoder etter tomt batteri Audi a4 b7
Noen som vet hvordan jeg får fjernet disse feilkodene? var ingen feilkoder der før batteriet var tomt bortsett fra antenna så må jo gå ann og fjerne dem igjen. har bla ikke multifunksjonsratt så den burde det ikke være feil på:-)
Tuesday,01,July,2014,00:18:40:52770
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WAUZZZ8EX8A080766 License Plate: SU52788
Mileage: 138860km-86283mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8EX8A080766 Mileage: 138860km/86283miles
Address 01: Engine Labels: 03G-906-016-BPW.clb
Part No SW: 03G 906 016 KM HW: 03G 906 016 KM
Component: R4 2,0L EDC G000SG 9896
Revision: --H05--- Serial number: XXXXXXXXXXXXXX
Coding: 0000172
Shop #: WSC 66565 257 00032
VCID: 78FF11360B1D69DEA37-802D
No fault code found.
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH
Component: ESP8 quattro H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004529
Shop #: WSC 06335 000 00000
VCID: 2E53F76EB9D9676E39B-807B
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 3233
Coding: 00000
Shop #: WSC 00000
VCID: 6DD13062275FDC76401-515E
1 Fault Found:
00716 - Air recirculation Flap Positioning Motor (V113)
41-00 - Blocked or No Voltage
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 11141
Shop #: WSC 65536
VCID: 3D71C02237BF8CF6B01-4B1C
1 Fault Found:
01326 - Control Module for Multi-Function Steering Wheel (J453)
49-10 - No Communications - Intermittent
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H14 4230
Revision: 91H14423 Serial number: 0036M0GA71E-
Coding: 0030612
VCID: 3B75CE3A7AAB82C68E5-806E
Subsystem 1 - Serial number: 6332DRB405C54FAA1
Subsystem 2 - Serial number: 6342DRB405E30AAC
Subsystem 3 - Serial number: 6352ARB402E5EE2B1
Subsystem 4 - Serial number: 6362ARB402D95822O
Subsystem 5 - Serial number: 63729RB402A612307
Subsystem 6 - Serial number: 63829RB402A60DDD+
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 01042
Shop #: WSC 06335
VCID: 4189BCD24B47E816D49-4B34
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 901 H HW: 8E0 920 901 H
Component: KOMBI+WFS 4 H14 0200
Revision: 0200 Serial number: 00000000000000
Coding: 0007118
Shop #: WSC 00150 218 177644
VCID: 2A5BFB7E86310B4EE53-5140
1 Fault Found:
00562 - Sensor for Oil Level/Temperature (G266)
010 - Open or Short to Plus - Intermittent
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0007118
VCID: 2A5BFB7E86310B4EE53-515E
1 Fault Found:
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CM
Component: Komfortgerát T23 4336
Coding: 07008
Shop #: WSC 06335
VCID: 7EF3072E7A3957EEE9B-4B1C
Subsystem 1 - Part No: 8E1959801H
Component: Tõrsteuer.FS BRM 0606
Subsystem 2 - Part No: 8E1959802H
Component: Tõrsteuer.BF BRM 0606
Subsystem 3 - Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000005
VCID: 3D71C02264BF8CF6B01-8068
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8E0 035 186 AK HW: 8E0 035 186 AK
Component: R Concert2+ H04 0240
Revision: 00H04000 Serial number: AUZ1Z3G5373885
Coding: 0010021
VCID: 70EF2916606D319E6B7-5140
2 Faults Found:
00856 - Radio Antenna
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 243
Time Indication: 15
00821 - Antenna 2 for Radio (R93)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 243
Time Indication: 15
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 D HW: 8E0 919 283 D
Component: Parkhilfe 4-Kan H06 0010
Revision: 00H06000 Serial number: 00067802020725
Coding: 0010114
VCID: 3169EC12ABE77896249-515E
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Time Indication: 0
End ---------------------------------------------------------------------
