#1 Skrevet Desember 27, 2014 Hei merket plutselig at webasto og varmeseter kuttet ut her om dagen , leste ut feilkoder og resultatet ble : Saturday,27,December,2014,12:03:08:41851 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 14.10.0.0 Data version: 20141022 VIN: WVGZZZ1TZ6W138444 License Plate: AX90779 Mileage: 223060km-138603mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 1T (1K0) Scan: 01 03 08 09 15 16 17 18 19 25 37 42 44 46 52 55 56 62 69 72 76 VIN: WVGZZZ1TZ6W138444 Mileage: 223060km-138603miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 18-Aux. Heat -- Status: Cannot be reached 1100 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: Cannot be reached 1100 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 69-Trailer -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BKC.lbl Part No SW: 03G 906 021 KC HW: Component: R4 1,9L EDC G000SG 9243 Revision: --H03--- Serial number: VWZ7Z0F3379876 Coding: 0000072 Shop #: WSC 00610 218 67795 VCID: 6ADBCCEA45DC9271D1F-803F 1 Fault Found: 001025 - EGR System P0401 - 000 - Insufficient Flow Freeze Frame: Fault Status: 01110000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 223047 km Time Indication: 0 Date: 2000.00.00 Time: 15:09:07 Freeze Frame: RPM: 1785 /min Speed: 26.0 km/h Load: 23.1 % Duty Cycle: 14.6 % Duty Cycle: 100.2 % Mass Air / Rev.: 270.0 mg/str Mass Air / Rev.: 530.0 mg/str Readiness: 0 0 0 0 1 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA Component: ESP FRONT MK60 0102 Revision: 00H13001 Coding: 0021190 Shop #: WSC 01324 785 00200 VCID: 71E9DB86680A61A9905-8024 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No: 1K0 907 044 BE Component: ClimatronicPQ35 090 0808 Shop #: WSC 00000 000 00000 VCID: 6BD5C9EE4A268B79AA9-803E No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl Part No SW: 3C0 937 049 E HW: 3C0 937 049 E Component: Bordnetz-SG H37 1002 Revision: 00H37000 Serial number: 00000005441665 Coding: EB8B8F2101040F0000120C000000000000087F075C Shop #: WSC 01324 785 00200 VCID: 2B5509EE8AA64B79EA9-807E Subsystem 1 - Part No: 1T0 955 119 C Labels: 1KX-955-119.CLB Component: Wischer VW358 012 0401 Coding: 00065493 Shop #: WSC 01324 Subsystem 2 - Component: Fehler Lin-Slave 02 6 Faults Found: 02092 - Enabling Heated Seat 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 5 Fault Frequency: 1 Reset counter: 65 Mileage: 223047 km Time Indication: 0 Freeze Frame: ON Voltage: 14.05 V ON ON OFF OFF OFF 00834 - Signal for Activation of Heated Rear Window 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 5 Fault Frequency: 1 Reset counter: 105 Mileage: 223061 km Time Indication: 0 Freeze Frame: OFF Voltage: 12.40 V OFF ON OFF OFF OFF 02071 - Local Databus 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 65 Mileage: 223047 km Time Indication: 0 Freeze Frame: ON Voltage: 14.05 V ON ON OFF OFF OFF 00978 - Lamp for Low Beam; Left (M29) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 1 Fault Frequency: 1 Reset counter: 105 Mileage: 223053 km Time Indication: 0 Freeze Frame: ON Voltage: 14.45 V ON ON OFF OFF OFF 01207 - Control Module for Auxiliary Heater (J364) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 6 Reset counter: 65 Mileage: 223047 km Time Indication: 0 Freeze Frame: ON Voltage: 14.05 V ON ON OFF OFF OFF 01520 - Rain and Light Recognition Sensor (G397) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 65 Mileage: 223047 km Time Indication: 0 Freeze Frame: ON Voltage: 14.05 V ON ON OFF OFF OFF ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1T0-909-605.lbl Part No SW: 1T0 909 605 C HW: 1T0 909 605 C Component: 02 AIRBAG VW62 0506 1500 Revision: 09025000 Serial number: 0038BD0HBKFC Coding: 0012338 Shop #: WSC 01324 785 00200 VCID: 35612F965CE20D898CD-8060 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG Component: J0527 034 0070 Coding: 0002022 Shop #: WSC 01324 785 00200 VCID: 77FDE59E066E3F995E1-8022 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 007 0050 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No: 1T0 920 872 FX Component: KOMBIINSTRUMENT VDD 4312 Coding: 0007101 Shop #: WSC 49732 000 1048576 VCID: 0F2DBD7E1EFE1759E61-805A 1 Fault Found: 01771 - Control Module for Headlight Range (J431) 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 18: Aux. Heat Cannot be reached ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb Part No SW: 1K0 907 530 F HW: 1K0 907 951 Component: Gateway H10 0120 Revision: H10 Serial number: 28001062160102 Coding: 7D3F5748078002 Shop #: WSC 01324 785 00200 VCID: 2A5B0CEA855C527111F-807F 2 Faults Found: 01207 - Control Module for Auxiliary Heater (J364) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 5 Reset counter: 65 Mileage: 223047 km Time Indication: 0 Date: 2000.00.00 Time: 15:05:35 01771 - Control Module for Headlight Range (J431) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 65 Mileage: 223061 km Time Indication: 0 Date: 2000.00.00 Time: 11:58:19 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No: 1T0 920 872 FX Component: IMMO VDD 4312 Shop #: WSC 49732 000 1048576 VCID: 0F2DBD7E1EFE1759E61-805A No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 1K0-035-191.lbl Part No SW: 1K0 919 887 K HW: 1K0 035 191 E Component: J401 0111 Revision: 00013000 Serial number: VWZ1Z2F6096266 Coding: 0041400 Shop #: WSC 01324 785 00200 VCID: 41894B46182AB129205-8014 1 Fault Found: 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 00000011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 65 Mileage: 223047 km Time Indication: 0 Date: 2000.00.00 Time: 15:05:33 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl Part No: 1T0 959 701 B Component: Tuer-SG 024 2301 Coding: 0000244 Shop #: WSC 01324 785 00200 VCID: 3663289A41E40691857-8063 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K1 909 144 K Component: EPS_ZFLS Kl.5 D06 1701 Shop #: WSC 00000 000 00000 VCID: 3365118E529613B9A29-8066 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb Part No SW: 1K0 959 433 AR HW: 1K0 959 433 AR Component: 01 KSG PQ35 G2 010 0101 Revision: 00010000 Serial number: 00000000000000 Coding: 009002085103487F00020F0FF0084F00E0A760 Shop #: WSC 01324 785 00200 VCID: 000F8E4253A078216FB-8055 Subsystem 1 - Component: Sounder n.mounted Subsystem 2 - Component: NGS n.mounted Subsystem 3 - Component: IRUE n.mounted No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl Part No: 1T0 959 702 B Component: Tuer-SG 024 2301 Coding: 0000244 Shop #: WSC 01324 785 00200 VCID: 377D259E46EEFF999E1-8062 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Cannot be reached ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl Part No: 1K0 959 703 E Component: Tuer-SG 021 2428 Coding: 0000144 Shop #: WSC 01324 785 00200 VCID: 326B148AAD8C1AB1A9F-8067 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer Cannot be reached ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl Part No: 1K0 959 704 E Component: Tuer-SG 021 2428 Coding: 0000144 Shop #: WSC 01324 785 00200 VCID: 3365118E529613B9A29-8066 No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 1K0-919-283.lbl Part No: 1K0 919 283 A Component: 02 Einparkhilfe 0101 Shop #: WSC 00000 000 00000 VCID: 2D5107F6B4B24549F4D-8078 No fault code found. End-------------------------(Elapsed Time: 02:34)-------------------------- Noen som har peiling på hva dette kan være ? dårlig batteri kanskje ? 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#2 Skrevet Desember 27, 2014 Sett batteri på lading over natta og slett feilkoder, kjør en tur og se etterpå hva som har kommet tilbake. 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#3 Skrevet Desember 27, 2014 14 volt under div freeze frames jo 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#4 Skrevet Desember 27, 2014 sjekket sikringer? 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#5 Skrevet Desember 27, 2014 Har sjekket sikringer men kun en som var røket i boksen i motorrummet , det hjalp ingenting å bytte den eller . Mulig feil på komfortstyremodulen også kanskje ? 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#6 Skrevet Desember 28, 2014 Akkurat samme problem har jeg å i min 08 passat, der var også 1 20amp sikring røket, men hjalp ingenting å bytte denne.. 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#7 Skrevet Desember 28, 2014 Mistenker faktisk et rele inni bilen som har laget en del lyd , hørt ut som at releet har slått ut og inn til tider men er helt stille nå i tillegg så kutter faktisk strømmen i speedometeret ut når jeg slår av tenningen og starter bilen på nytt er det akkurat som jeg har koplet av batteriet alt er nullstilt 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
