#1 Skrevet Januar 9, 2015 Har noen ubrukte LED pærer til tåkelysene, selges grunnet at jeg kjøpte feil. Selges for 300,- + evt frakt Pærene er av typen OPT7 LED Plasma 6000k cool white H11 (H8, H9): Info hentet fra salgsannonse: Bulb Specs 4 Panel + Projector Nova Plasma LED light 11 Watts - 680 lumens (medium-range light) 50,000 hour bulb life 100% Water and rumble-resistant Easy-to-install, Plug'n'Play 2 BULBS ONLY! No ballast needed Cosmetic use only! Not rated for road use Enhance Your Car, In Five Minutes... Easily replace your dull and uninspiring halogen fog lights with clean and vivid Nova Plasma light. OPT7™ Nova Plasma LED Light Shining brighter than standard halogen, Nova plasma LEDs are the best way to complement your custom lighting without blinding oncoming traffic. Easy Plug-N-Play Installation Plugs directly into your stock lighting system. No ballasts The last replacement you'll need A 50,000 hr life and a watertight aluminum casing, your Nova LED light might even outlast your car! Plasma LED Side-Panels: Brighter LED light, emitting 680lm (slightly brighter than halogen) CREE Projector LED: Throws forward a focused beam of light Solid State Design: Lasts a very long time (50k hrs) IP65 Water and Rumble resistant Plug-N-Play: No ballast, no soldering A great way to update your car's fog light appearance. Not for road use! 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
