hei har fått problem med ABS systemet å finner ikke ut hva det er.
symptomer
ABS lys lyser konstant
(!) bremse lys blinker
speedometer fungerer ikke
piper 3 ganger når jeg skrur på tenning
går bare på 3 sylindrer av og til
har sjekket alle sikringer
har byttet alle sikringer
har sjekket at jeg har strøm til ABS modul
har sjekket sikringen på batteriet
har prøvd å bytte abs modul med en eksakt lik
feil koder
CDS Version: Release 14.10.0 (x64)
Data version: 20141022
Monday,19,January,2015,16:13:18:50350
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8E13A376669 Mileage: 231330km-143741miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 JT
Component: 1,9l R4 EDC 0000SG 1572
Coding: 00003
Shop #: WSC 63251
VCID: 72EBEA243E6B8FB169F-4B00
WAUZZZ8E13A376669 AUZ6Z0C0100194
2 Faults Found:
18061 - Please check DTC Memory of ABS Controller
P1653 - 35-10 - - Intermittent
18057 - Powertrain Data Bus
P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
Readiness: 0 0 X X X
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AD
Component: A4 Klimaautomat 1219
Coding: 00000
Shop #: WSC 63251
VCID: 63C59F60F1911639129-5140
1 Fault Found:
01312 - Powertrain Data Bus
79-00 - Please Check Fault Codes
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00111
Shop #: WSC 63251
VCID: 34672C3C04FFC181BB3-4B00
4 Faults Found:
01496 - Bulb for Fog-Lamps; Left (L22)
57-00 - Electric Circuit Failure
01500 - Bulb for Fog-Lamps; Right (L23)
00988 - Lamp for Brake Light; Right (M10)
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 B
Component: Airbag 8.4EP 2000
Coding: 0010602
Shop #: WSC 63251 000 00000
VCID: 366316344283D391857-5140
2 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
00474 - Control Module for Immobilizer
004 - No Signal/Communication - Intermittent
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0308
Coding: 04012
Shop #: WSC 63251
VCID: 3E730E143AB31BD15D7-4B00
3 Faults Found:
01301 - Control Module for Voice Recognition (J507)
49-10 - No Communications - Intermittent
01303 - Telephone Transceiver (R36)
01304 - Radio
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 930 R
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 01000
Shop #: WSC 00170
VCID: 366316341283D391857-5140
1 Fault Found:
01316 - ABS Control Module
49-00 - No Communications
Address 37: Navigation Labels: 4B0-035-192-RNSD-37.lbl
Part No: 8E0 035 192 B
Component: RNS 4.2 H06 BNO 0102
VCID: 2345DF60B1115639529-4AE8
2 Faults Found:
00625 - Vehicle Speed Signal
03-00 - No Signal
65535 - Internal Control Module Memory Error
00-00 - -
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 BA
Component: Komfortgerát TA7 1310
Coding: 06976
Shop #: WSC 63251
VCID: 71E9E5283B6DB4A9905-4B1A
Subsystem 1 - Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0003
Subsystem 2 - Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0003
14 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
01317 - Control Module in Instrument Cluster (J285)
01562 - Rear right door
59-10 - Can't Unlock - Intermittent
61-10 - Won't De-Safe - Intermittent
00955 - Key 1
35-00 - -
00956 - Key 2
35-10 - - - Intermittent
37-10 - Faulty - Intermittent
00466 - Control Module for Steering Column Electronics (J527)
01559 - Drivers Door
58-10 - Can't Lock - Intermittent
01705 - Selection Switch for Mirror-Adjust (E48)
27-10 - Implausible Signal - Intermittent
01034 - Electric Window Thermal Protection Active; Driver
01331 - Door Control Module; Driver Side (J386)
01560 - Passenger Door
61-00 - Won't De-Safe
01332 - Door Control Module; Passenger Side (J387)
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63251
VCID: 0407BCFC14DFB1014B3-4B32
1 Fault Found:
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
30-00 - Open or Short to Plus
Address 56: Radio Labels: 4B0-035-192-RNSD-56.lbl
Component: Radio BNO 0001
Coding: 00207
Shop #: WSC 06342
1 Fault Found:
00852 - Loudspeaker(s); Front
36-00 - Open Circuit
Address 67: Voice Control Labels: None
Part No: 8E0 035 753 A
Component: Sprachbediensystem 0200
Coding: 0018015
VCID: 2541C178EF25A8093CD-50CC
No fault code found.
Address 75: Telematics Labels: Redir Fail!
Part No: 8E0 035 617 A
Component: Telematik Nokia1 0303
Coding: 0005324
Shop #: WSC 00000 785 00200
VCID: 2447DC7CE41F51012B3-51B6
5 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
00469 - Infotainment Databus in Single Wire Operation
012 - Electrical Fault in Circuit - Intermittent
01522 - Handset for Telephone (R37)
01531 - Emergency Battery
Address 76: Park Assist Labels: 8E0-919-283-8E2.lbl
Part No: 8E0 919 283 A
Component: Parkingsyst. A4 RDW D08
Coding: 00114
Shop #: WSC 63251
VCID: 2E533E54EAD3EB51CD7-515E
3 Faults Found:
27-00 - Implausible Signal
01550 - Signal for Reverse Gear
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
31-00 - Open or Short to Ground
får ikke til og koble til abs modul
For meg kan det se ut som en Can-Bus feil, eventuelt en komponent som er ødelagt og forstyrrer signalet.
Du har feilkode 01312 som går igjen. Har ingen gode ideer om hvor starte, men finn tak i ett koblingskjema og ett multimeter :)
01312- Powertrain Data Bus: Faulty
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Immobilizer Communication blocked / Engine Start blocked
Possible Causes
Databus Wiring and/or Connector(s) faulty
Control Module(s) faulty
Possible Solutions
Check Databus Wiring and/or Connector(s)
Check Control Module(s)
Start med det mest åpenbare, hvordan ser polene på batteriet ut? Har opplevd at tung irring/dårlig kontakt her gir rare feilmeldinger over hele lista.
Har sjekket bateriet å tilkoblingene ser helt fine ut:)
Ja er en mulighet :) men så er spørsmålet hvor skal jeg starte. Får heller ikke koblet til can med vag-com: bh : og hvor får jeg tak i et koblings skjema til bilen
Og så lurer jeg på om det er flere sikringer å rele en de som sitter på siden av dersj bordet, under rattet og inni boksen hvor ecu en ligger ?
Åssen er spenninga på batteriet?
Koblings skjema finner du på ElsaWin.
Det finner du på Google eller Ebay. Kjører du nyere operativsystem enn XP trenger du ElsaWin 4 eller nyere.
Spenninga er fin den :)
Takk ska sjekke det ut:)
finner ikke ut av dette å bynner og bli passelig frustrert : bh : noen andre tips og triks ?
får ikke kontakt med CAN på vag-com er det noen som vet om det er pga at abs modulen er gåen eller at jeg ikke har kontakt med den. eller kan det være andre årsaker til at jeg ikke får kontakt med CAN som igjen gjør at jeg ikke får kontakt med abs modulen.
har holdt på i times vis i dag og feil søkt og styrt og klarer ikke og finne noe og abs enheten som jeg har montert har jeg selv demontert på huggern og da virket den fint på den bilen den sto på.
kan det være at batteriet er dårlig ? har hadd batteriet på ladding inni gararsjen og plugget i fra + og - polene og satt laderen rett på batteriet ladde med 4 amp i 1 døgn og da når jeg målt bateriet hadde jeg 12,5v og så fikk det stå i 12 timer og da var det bare 11,48v, batteriet har stådd frakoblet.?? er desperat er ikke så interessert i og bruke så sykt mange tusen til da jeg allerede har brukt 3k på ny abs modul og 5 på en vagcom siden det er langt til nermeste audi verksted.
Kan virke som det er en celle i batteriet ditt som er ødelagt. Da detter spenningen med 2V.
Koble til batteriet og sett på laderen, la det stå en 30-50 min, så slå på tenningen, mål spenningen burde være på 13V eller mer med lader tilkoblet, så se om du får kontakt med bilen igjen. (ikke ta av eller slå av laderen) Eventuelt lån batteriet til en kompis.
Virker det nå er det batteriet.
Om det ikke virker, kan det være en modul som lager krøll i kommunikasjonen. Kan jo begynne med å koble fra klima panelet, da jeg har hatt problemer på en bil tidilgere med at denne forstyrret CAN signalet.
Edit: Jeg villet slettet alle feilkodene og tatt en liten kjøretur, så sett hvilke feilkoder som kom tilbake. Om du ikke vil kjøre en tur så slett dem likevel og se hvilke som kommer tilbake. Men ha mer enn 12V på batteriet før du gjør det :) (lader tilkoblet/motor igang)
har byttet batteri nu å får fortsatt ikke kontakt med can bus!!! har prøvd å slette alle feil koder alle kommer tilbake har også prøvd å koblet ifra klima panelet men ingen forskjell!! dette problemet kom etter at jeg drog ut sikring 42 med motoren igang med en feiltakelse! er litt usikker om det kan være sælve abs pompa som lager krøll da jeg tydelig kunne høre at pumpa gikk 2 ganger etter at jeg plugget inn sikringen? å er det da mulig at jeg har svidd den nye abs modulen da jeg først bare byttet modulen? prøvde siden og montere den nye abs pompa også men er redd for at jeg kanskje ødela modulen er det mulig at dette kan skje ??
Sikring 42 går til ABS enheten.
Vet ikke om du skal henge deg opp i at du ikke får kontakt med CAN. Da det virker som du får kontakt med modulene rundt i bilen ellers. Du må få tak i koblingskjema og se over feilkodene, kan være en enkel årsak til at de kommer.
CAN-001.pdf
Koblingskjema ABS-001.pdf
Hva var grunnen til at du dro ut sikring 42?
var en kompis som hadde dradd ut et par sikringer før å være artig så blei det bare tull : mad :: bh :
[ATTACH]220664[/ATTACH]
[ATTACH]220665[/ATTACH]
ja kan være en enkel ting men så er det og finne ut hvor har sedd på disse koblings skjemaene fra elsawin men plages med og skjønne dem!
Har laget en enkel forklaring her, basert på CAN skjemaet. Dette er med Automatgir.
Men kan være du må krype til koset og levere bilen på verksted for feilsøk, om ingen andre glupe hoder her inne kommer med tips.
CAN-lett forklart.pdf
da var abs problemet fikset! tusen takk for hjelpen Kenneth:tilber:
fant ut av det ved hjelp av det abs koblings skjemaet var dårlig kontakt i den kabelen som går fra tenninga og til sikring 7
men får ikke motoren til og gå rent motoren høres ut som en boxser motor! har sjekket registret og det er helt rett!
har ikke peiling på hva det kann være!
kan det være luft mengde måleren har vældig ujevne verdier fra ca 340-590 på tomgang
Ta en ny diagnose nå som det store problemet erfikset, kanskje du får opp noe som forteller om hvorfor motoren ikke går som den skal.
har tadd en ny diagnose og får ingen feil koder opp. Alle feilkoder som har vært er borte!
Da vet du at feilen er av mekanisk karakter, som f.eks. at en av sylinderne trolig ikke får diesel. Det er vel en pumpedysemotor?
Har funnet problemet! Er kammen på bilen som er gåen: bh :
