#1 Skrevet Februar 14, 2015 Lite brukt ledbar til salgs. Sitter montert på takstativ for railing. Sitter 3m ledning på ledbaren. Medlempris: 1200 uten stativ. 1500 med stativet (Mont Blanc i alu, låsbart.) Feature: 1.Wide operating voltage range? 2.The appearance of fine craft and easy to install brackets. 3.Different sizes to choose from installed in different locations. 4.Different light pattern from flood beam and spot beam. 5.Long life: more than 30000 hours 6.Aluminum casing? shock-proof waterproof better. 7.Light perception: a softer light to prevent glare. SPECIFICATION 1.Input Voltage: 10-30V DC 2.Total Wattage: 180W 3.Ingress Protection: IP67 4.Color Temperature: 6000-6500k 5.Working temperature: -40 -80 6.Dimension: (34inch*4.48inch*3.4inch) 7.Weight: 4.7kg 8.Beam Angle: 60 / 30 (FLOOD 60 ; SPOT 30 ) 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
