Loba / Sachs 650 stage 2+ clutch selges til s4/rs4 B5
Har en Loba 650/Sachs stage 2+ clutch til salgs. Stått på sedanen, har balansert med annet svinghjul og trykkplate, så selger denne om noen er interessert. Er lite brukt, kjørt noen turer langs vei med prøveskilt, og 1.5 dag på rudskogen. Max 150 mil.
Denne holder mer enn de beskjedne 650nm den er oppgitt til, andre har bremsa bortimot 800 nm med denne clutchen, uten at den glipper. Føles veldig lik Oem clutch.
Det som inngår:
Loba lettet svinghjul
Lamell
Sachs Trykkplate
Brukte trykkplate bolter
Brukte svinghjulsbolter om ønskelig (svinghjulsboltene skal benyttes bare en gang)
Pris 8000, evt bud.
Sendes ikke, bør hentes.
Ser de koster rundt 13000 i utlandet +norske avgifter
Sakset fra WOTmotorsport sine sider
Stage 2+ - 650nm Clutch & Flywheel Kit -
This kit is ideal for those who want to remove the OE dual mass flywheel and replace it with a single mass unit. The organic clutch disc offers great driveability while being able to cope with much more torque than a standard rs4 clutch and is another step up from the 600 Nm option.
A reinforced clutch cover has fundamental advantages against an OEM clutch cover, such as a higher transmittable torque and higher resistance against thrust yet retains a very OEM feel due to a organic friction plate used. This makes it extremely useful for tuned cars and suits cars with bigger turbos, and for vehicles that are often driven with their maximum gross vehicle weight. It also allows for faster and sportier gearshifts.
LOBA billet flywheel. The fact that the flywheel provides 50% of the friction surface to which the disc mates and consequently half of the holding power. For maximum clutch performance, the billlet material is carefully chosen that surface must have maximum compatibility, flat and true with the disc friction material for smooth engagement and to take advantage of the increased coefficient of friction of a high performance clutch disc. Without this compatibility, the power or torque capacity of the entire clutch system is seriously compromised. Also LOBA billet flywheels are balanced to far higher precision than stock and much lighter.
There are completely different requirements for a clutch in motorsports. Special attention is paid to lightweight and mass moment of intertia (MMI) in order to achieve the maximum acceleration of the engine as well as shorter shifting times. Thanks to a smaller clutch diameter and exclusive materials a significant reduction of weight and MMI is achieved in these kits.
The LOBA-Sachs single disc sports clutch kits include
Sachs Performance clutch cover
Sachs Performance clutch disc organic 650 Nm
LOBA Billet lightened & balanced single-mass flywheel made of special chromoly steel (7.7 KG)
needle bearing
clutch cover screws
