Webasto trøbbel, styreenhet?
Webastoen på vår 2006 A3 ville ikke starte denne høsten, og etter diagnose får jeg opp feilen "Control unit, defective"
Er det bare å bytte boksen, eller kan det være noe annet? Har fungert feilfritt i de 3 årene vi har hatt den, men har jo selvsagt ikke vært brukt siden våren.
Fant dette i en webastomanual
13. Fault Lock-out
The control unit continuously monitors the heater operation. The control unit identifies errors on individual heater
components and faults during operation. Should the control unit experience component errors and operational faults,
the heater will be shut down.
The heater is shut down (fault lock-out) if:
– No or incorrect start
– Temperature sensor defective
– Overheating sensor interrupt or short circuit
– Overheating sensor installed incorrectly
– Ceramic glow pin interrupt or short circuit
– Fan motor overload or blocked or short circuit or interrupt
– Error in the fuel metering pump or overheating guard circuit (start phase only)
– Under voltage less than 10 V or over voltage greater than 15 V and for longer than 20 seconds (on 12 V heater)
– Under voltage less than 20 V or over voltage greater than 32 V and for longer than 20 seconds (on 24 V heater)
– Control unit defective
– Overheating
The fuel supply is stopped if the heater overheats.
The heater continues to run in the same way as if it is switched off manually.
After the heater stops the control unit will be set to fault lock-out.
Overheating is indicated by the indicator flashing 10 times.
Rectify the cause of the fault.
To reset the fault, switch the heater on and off briefly (at least 2 seconds).
If serious faults, such as overheating or no start, occur frequently, the heater will be set to fault lock-out (F 12) and can
be restarted by disconnecting the supply voltage (e.g. removing the fuse).
Hvilken webastomodell har du?
Du kan se om det har låst seg hvis du tar en diagnose.
Se andre feilkoder som kan ha ført til dette.
Da må du i tilfelle "unlocke" den,
Det gjøres i litt forskjellige kanaler avhengig av hvilken type du har.
Styrer med det samme med min,og det er en 2011 modell webasto,som jeg er ganske sikker på at styreenheten er defekt.
Koppler jeg av strømmen noen minutter så virker den fint inntil jeg har starter den 2-3 ganger.
Vet ikke eksakt hvilken modell det er, men feilmeldingen sier tydelig at styreenheten er defekt, og ikke at den er låst (har låst den opp en gang for ett par år siden).
Snakket med ett verksted i dag, og han sa "rengjør dritten" med en gang jeg nevnte Webasto, så jeg får prøve det først :D
Ok,ikke helt tilhenger av Webasto han kansje,hehe:-)
Kansje greit å sjekke el.koplingene/ledninger å,i og med at det er en feilmld på noe elektrisk du får fram.
Tenker du å åpne hele greia,og rengjøre brennkammer og alt da?
Jeg får blant annet denne feilmld.
01299 - Diagnostic Interface for Data Bus (J533)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 2
Reset counter: 163
Mileage: 210160 km
Time Indication: 0
Hadde tenkt å demontere den helt ja, men venter til juleferie slik at jeg slipper å stresse med det...
Hvor ligger styreenheten?
Ok.
Er ikke helt sikker,men tror det er hele den enheten på webastoen som du kopler ledningene til.
Som på bildet.
