#1 Skrevet Januar 9, 2016 Jeg leste ut feilkoder for en kvinnelig kollega da hun har hatt problemer med det elektroniske håndbrekket på bilen i emnefeltet, og det kom om andre feilkoder. Address 01: Engine Labels: 03G-906-016-BKC.lbl Part No SW: 03G 906 021 LR HW: 03G 906 021 AN Component: R4 1,9L EDC G000SG 9248 Revision: --H07--- Serial number: VWZCZ000000000 Coding: 0000071 Shop #: WSC 05311 000 00000 VCID: 7AFBBBCE35A748EE25-802E 1 Fault Found: 005488 - Engine Start Blocked by Immobilizer P1570 - 000 - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 4 Reset counter: 255 Mileage: 173057 km Time Indication: 0 Date: 2015.12.15 Time: 10:04:29 Freeze Frame: RPM: 1260 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 11.25 V Bin. Bits: 00001111 Bin. Bits: 11000000 Bin. Bits: 00100001 ------------------------------ Address 18: Aux. Heat Labels: 1K0-815-071.clb Part No: 1K0 815 071 T Component: Zuheizer 050 2504 Revision: 00050000 Serial number: 09009839000000 Coding: 0000011 Shop #: WSC 05311 000 00000 VCID: 36636FFE413F6C8E81-8062 3 Faults Found: 01406 - No Flame 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 17 Reset counter: 85 Mileage: 171083 km Time Indication: 0 Date: 2015.10.27 Time: 12:18:50 Freeze Frame: Start Temperature: 66.0°C Temperature: 68.0°C Voltage: 14.53 V 01407 - Flame Extinguished 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 4 Reset counter: 122 Mileage: 171678 km Time Indication: 0 Date: 2015.11.10 Time: 12:45:16 Freeze Frame: Start Temperature: 59.0°C Temperature: 60.0°C Voltage: 14.53 V 02251 - Heater Unit Locked 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 85 Mileage: 172678 km Time Indication: 0 Date: 2015.12.08 Time: 08:14:17 ----------------------------- Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb Part No SW: 3C0 907 530 C HW: 3C0 907 951 A Component: Gateway 007 0040 Revision: 00007000 Serial number: 0700C075040128 Coding: 3DFD8C04CA2002 Shop #: WSC 05311 000 00000 VCID: 2149ACA2F8B1FB3644-8074 1 Fault Found: 01207 - Control Module for Auxiliary Heater (J364) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 4 Reset counter: 163 Mileage: 172897 km Time Indication: 0 Date: 2015.12.10 Time: 10:17:18 --------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.clb Part No SW: 3C0 959 433 R HW: 3C0 959 433 R Component: IMMO 042 0383 Revision: 00042000 Serial number: VWZCZ000000000 Shop #: WSC 131071 1023 2097151 VCID: 397964C2702183F66C-806C Subsystem 1 - Part No: 3C0 905 861 G Component: ELV 027 0380 3C0905861G ELV 027 0380 3 Faults Found: 02823 - Requirements for Locking the Steering Column Lock not met 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 4 Reset counter: 162 Mileage: 173438 km Time Indication: 0 Date: 2015.12.20 Time: 21:49:11 02827 - Wake-Up request via ESP 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 4 Reset counter: 162 Mileage: 173438 km Time Indication: 0 Date: 2015.12.20 Time: 21:49:12 02861 - Electronic Steering Column Lock Check Sum Error 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 4 Fault Frequency: 2 Reset counter: 146 Mileage: 173398 km Time Indication: 0 Date: 2015.12.19 Time: 15:44:08 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl Part No SW: 1K0 959 701 P HW: 1K0 959 793 L Component: J386 TUER-SG FT 1131 Revision: 32008001 Serial number: 00000514378331 Coding: 0000245 Shop #: WSC 05311 000 00000 VCID: 3B757ECA7A1DB1E67E-806E 1 Fault Found: 00932 - Electric Window Motor; Drivers Side (V147) 005 - No or Incorrect Basic Setting / Adaptation - Intermittent Freeze Frame: Fault Status: 00100101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 146 Mileage: 173373 km Time Indication: 0 Date: 2015.12.18 Time: 14:23:18 ----------------------------------------- Address 53: Parking Brake Labels: 3C0-907-801-53.clb Part No SW: 3C0 907 801 E HW: 3C0 907 801 E Component: EPB VC8HC003 013 0003 Revision: 013 Coding: 0000012 Shop #: WSC 05311 000 00000 VCID: 2447A5B6E7A3EE1E2F-8070 3 Faults Found: 02428 - Left Parking Brake Motor (V282) Clamping Force Not Reached 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00110010 Fault Priority: 6 Fault Frequency: 4 Reset counter: 168 Mileage: 174080 km Time Indication: 0 Date: 2016.01.01 Time: 01:34:37 Freeze Frame: Voltage: 7.97 V Count: 204 02432 - Supply Voltage for Left Parking Brake Motor (V282) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00111100 Fault Priority: 1 Fault Frequency: 6 Reset counter: 168 Mileage: 174056 km Time Indication: 0 Date: 2015.12.31 Time: 13:37:55 Freeze Frame: Voltage: 13.87 V Count: 86 02430 - Left Parking Brake Motor (V282) Resistance to Movement 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00110011 Fault Priority: 3 Fault Frequency: 4 Reset counter: 164 Mileage: 174056 km Time Indication: 0 Date: 2015.12.31 Time: 13:36:14 Freeze Frame: Voltage: 13.56 V Count: 88 ----------------------- Caliperen er vel gåen på venstre side bak, men hva med de andre? Hva er mest trolig defekt på dieselvarmeren, og hva med startsperren? Hun sa at den hadde vært guffen noen ganger, hun måtte dytte nøkkelen ut og inn for at bilen skulle starte. 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#2 Skrevet Januar 9, 2016 No flame er at det er lite diesel på tanken så dieselvarmeren ikke starter. Men kan være mange av de som ikke er permanente feil. Slett alle feilkoder og ta en ny diagnose. De du får opp da er det hun burde ta en titt på evt 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#3 Skrevet Januar 9, 2016 Ja, jeg har slettet alt, men de på dieselvarmeren kom tilbake med en gang 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#4 Skrevet Januar 9, 2016 No flame er nok pga igjensotet brennkammer Ang calipper. Muligens bare håndbrekk motoren på calipern som er ødlagr . Vanlig feil på disse 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#5 Skrevet Januar 9, 2016 No flame er nok pga igjensotet brennkammerAng calipper. Muligens bare håndbrekk motoren på calipern som er ødlagr . Vanlig feil på disse Pleier anbefale alle kunder å skifte hele driten med en gang. Masse irr og drit inni der så enten skifter du reg.motor på nytt etter kort tid eller så er du så heldig at calipperen begynner å lekke evt ruste kort tid etter du har skiftet motor og da må du ha alt nytt igjen uansett 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#6 Skrevet Januar 10, 2016 Ja, jeg har slettet alt, men de på dieselvarmeren kom tilbake med en gang Du må vel låse opp webasto'en når den er låst. http://wiki.ross-tech.com/wiki/index.php/02251 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#7 Skrevet Januar 10, 2016 Pleier anbefale alle kunder å skifte hele driten med en gang. Masse irr og drit inni der så enten skifter du reg.motor på nytt etter kort tid eller så er du så heldig at calipperen begynner å lekke evt ruste kort tid etter du har skiftet motor og da må du ha alt nytt igjen uansett Hvor mye koster en slik jobb hos Møller? 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#8 Skrevet Januar 10, 2016 Hvor mye koster en slik jobb hos Møller? Møller tok 2500.- for skifte av håndbrekk-motor for et par år siden. Noen verksteder skifter kun motor, mens andre anbefaler skifte av calipper også. Skifte av motor er relativt enkelt (par skruer), men krever nullstilling etterpå. Dersom elektronikken i motor er gåen (p.g.a vanninntrengning->kortslutting) vil brekket ikke slippe og det piper bare når man trykker på knappen. Noen av feilene som oppgis kan være følgefeil. Feil på håndbrekkmotor er nok noe de aller fleste opplever på den generasjonen Passat. Calipper koster 4500.- på Mekonomen for 2007-modell, mens 5200.- for 2008-modell. Webasto-service er noe som fort koster noen lapper. En på jobben måtte ut med 9000.- for å fixe en Webasto på et annet bilmerke. Webasto kobler forøvrig automatisk ut dersom man er på reservetanken eller man har trykket inn ECON-knappen i Climatronic-en. Gjensoting er vel vanlig p.g.a mye småkjøring på mange biler. Kan være lurt å sjekke med verksteder som spesialiserer seg på Webasto-service. Prisene varierer mye. 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#9 Skrevet Januar 10, 2016 Kåler selv på en 2005 modell; får opp parking brake failure i display. Feilkoden indikerer feil på ledningsnett eller trykkbryter. Mottar ny bryter på tirsdag men frykter flere feil. Autohold'en funker heller ikke lengre. Men motorene summer fint når de først går. Hva er vanskelighetsgraden på å skifte kalipper med motor selv (for en som aldri har gjort det før)? Antar man også må lufte systemet etterpå? Har VCDS. 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#10 Skrevet Januar 10, 2016 Kåler selv på en 2005 modell; får opp parking brake failure i display. Feilkoden indikerer feil på ledningsnett eller trykkbryter. Mottar ny bryter på tirsdag men frykter flere feil. Autohold'en funker heller ikke lengre. Men motorene summer fint når de først går. Hva er vanskelighetsgraden på å skifte kalipper med motor selv (for en som aldri har gjort det før)? Antar man også må lufte systemet etterpå? Har VCDS. Trykkbryter er også en svakhet på de første modellene. Denne er også byttet på mange biler. Ny type er vistnok mindre sensitiv. Kjapt å skifte. Har hørt om flere som kun trengte å bytte bryter. Når det gjelder bakre calipper så er denne angitt med vanskelighetsgrad 4 av 5 i Haynes-boka (selges billig på Biltema), men dette skyldes nok at man må ha tilgang til diagnose for å kalibrere motor etterpå. Burde være greit å gjennomføre. Kun nødvendig å lufte bakre brems etterpå. 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#11 Skrevet Januar 10, 2016 Kåler selv på en 2005 modell; får opp parking brake failure i display. Feilkoden indikerer feil på ledningsnett eller trykkbryter. Mottar ny bryter på tirsdag men frykter flere feil. Autohold'en funker heller ikke lengre. Men motorene summer fint når de først går. Hva er vanskelighetsgraden på å skifte kalipper med motor selv (for en som aldri har gjort det før)? Antar man også må lufte systemet etterpå? Har VCDS. Utenom at du må grunninnstille calipper etterpå så er det akkurat som å skifte en vanlig calipper. I mange tilfeller hvis du er heldig holder det å bare åpne lufteskruen og la det renne ut bremsevæske så har du fått ut lufta(hvis du er heldig). 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#12 Skrevet Januar 10, 2016 Hva mener dere med nullstille/grunnstille motor? 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#13 Skrevet Januar 10, 2016 Hva mener dere med nullstille/grunnstille motor? Håndbrekkmotor må kjøres inn/ut ved skift av f.eks bremseklosser eller hele greia. 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
