Unique Golf Gti 16VG60 4x4 LTD.
The car is completely restored to the best detalj.det are signs on the car and it was approved by the European Union VWMS (Volkswagen Motorsport) made the package 72 cars with the engine 89, the engine is an exact replica of the original vwms some parts of the engine: engine KR / VW motor switching just passed some one thousand kilometers S2 pistons with new rings Scat H-profile handle all the shares, fill and seal new new Reims registry includes new flywheel new VR6 clutch new water pump motor Vibratechnics mounted exhaust G60 new Golf / Rallye Golf Rallye intercooler, new heater Rallye Golf G-charger is checked, repaired and moved by Ruud Droog NL new plug Bosch cables cover the rotor new NGK plugs new drive belt 2x rotor new belt new throttle pas Top blown glass and washed new valve guides and seals new pushers Mira hissed vantilseter and valves Planet new cylinder head bolts new OEM timing chain belt new timing set a new stuffing in transmission and bakdiff Inter axle completely rebuilt with all new parts of the body: a new door OEM new screens G60 OEM new OEM masks new front and rear new OEM Backplate new OEM wheel arches complete new set of G60 plastic ext fog lamps new All front lamps have been in France for painting (plate) inside, as some French cars were in the 80s VR6 Syncro suspension front and rear axles ling with Powerflex bushes. Bakstilling modified to adjust the toe and camber brakes front: discs 312x25mm Audi TT with a carrier TT 100 AUD / a6 57mm calipper rear brakes: VR6 280x22mm front sliced golf carrier MK IV R32 and terminal and custom adapter BBS LeMans LM 7x17 ET35 5x100 195 / 40 tires falcon all brackets / suspension etc are powder coated, all bolts are blown glass and yellow. A lot of new parts, clips screws, etc. Much of custom parts. Only a correct parts are used. the car is assembled only original screws in place. Photos of the construction obtained a copy of serious buyers for inspection. the car is built by Goran Krogh.
selge den allerede???
Er det bare meg som ikke ser en prisantydning? Flott bil iallefall.. :)
ligge ute på facebook på VW Golf Norway - KJØP & SALG for 159.000kr værtfall :)
Sorry as, men skal man selge en så spesiell bil internasjonalt, så burde man bruke noe annet enn Google Translate..
Tøff bil, og høyt opp på lista av drømmebiler! Men den fortjener en bedre annonse:)
