Smidde H-profil råder, ventilstyringer og Bensintrykksreg.
Har fremdeles igjen noen nye deler, alt er kjøpt når dollaren var lav (2013):
JDM(?) H-profilråder, kun tatt en ut av plasten for sjekk.
Nypris 4056,-
VACN-pris 3500,-
FUELAB bensintrykksregulator
Nypris 1110,-
VACN-pris 750,-
20 stk Freccia ventilstyringer
Nypris 65,- pr stk
VACN-pris 45,- pr stk.
mail: jao(a)vacn.no
tlf: 905 82 737
Ligger i veien.
ca halvpris nu!
Nypris 4056,-
VACN-pris 3500,-
Nypris 1110,-
VACN-pris 750,-
Nypris 65,- pr stk
mail: jao(a)vacn.no
tlf: 905 82 737
[ATTACH=CONFIG]249795[/ATTACH][ATTACH=CONFIG]249794[/ATTACH][ATTACH=CONFIG]249796[/ATTACH]
Har du noe mer info om den bensintrykksregultoren? Fuelab lager mange typer :-)
Rådene har mål for å passe i AAN med originale stempler, veiv og slaglengde.
Regulator 51502-1:
Fuelab 515 Series Fuel Pressure Regulators are designed with performance and flexibility in mind. They accept port style and non-port style union fittings without interference. Several configurations are available, supporting carbureted applications as low as 1 PSI to fuel injected applications up to 125 PSI.
FeaturesTwo -6AN or -10AN inlet ports and one -6AN return port
Gasoline, diesel, methanol, and ethanol fuel compatible
Billet Aluminum with anodize per military MIL-A-8625, Type II
Fine thread pitch for precise pressure adjustment
Versatile mounting bracket and stainless steel hardware
1/8" NPT gauge port with plug for external pressure gauge
1/8" NPT pressure reference port with barbed fitting
Hei, Jeg tar bensintrykksregulatoren! Skal jeg sende deg mail eller pm ?
