Clutchkit Passat 3bg med 01E, 1000kr
Legger ut for en venn:
Selges hbo 1000.-
Tlf: 97535975
Har overflaterust på skive da esken har vært lagret i garasje i lengre stund.
Følger også med tettering da denne er grei å bytte samtidig.
Info fra nett:
Brand: LuK
Part: Clutch Kit
Brand Part Number: 624303700
Technical Specification
SKU: 1344267_GEN_GB
Manufacturer Part Number: 624303700
Brand: LuK
Reference OE/OEM Number: Vw/038 198 141 EX Audi/06C 198 141 AX
Adjustment: with automatic adjustment
Supplementary Article/Info 2: Requires special tools for mounting
Supplementary Article/Supplementary Info: with clutch pressure plate
Chassis number to: 5#015000
Engine Version: for engines with dual-mass flywheel
Diameter [mm]: 240
Chassis number from: 2#000001
Chassis number to: 5E065675
Engine Code: AVF
Supplementary Article/Info 2: Check and replace dual-mass flywheel if necessary.
Supplementary Article/Info 2: with clutch plate
Supplementary Article/Info 2: with releaser
This product fits with the following models:
* Audi A4 Avant (8E5, B6) 1.9 TDI 01-04 {130,1896}
* Audi A4 Avant (8E5, B6) 1.9 TDI quattro 01-04 {130,1896}
* Volkswagen PASSAT (3B3) 1.9 TDI 00-05 {130,1896}
* Volkswagen PASSAT (3B3) 1.9 TDI 4motion 00-05 {130,1896}
* Volkswagen PASSAT Estate (3B6) 1.9 TDI 00-05 {130,1896}
* Volkswagen PASSAT Estate (3B6) 1.9 TDI 4motion 00-05 {130,1896}
* Audi A6 (4B, C5) 1.9 TDI 97-04 {130,1896}
* Audi A4 (8E2, B6) 1.9 TDI 00-04 {130,1896}
* Audi A6 Avant (4B, C5) 1.9 TDI 97-04 {130,1896}
* Audi A4 (8E2, B6) 1.9 TDI quattro 00-04 {130,1896}
OEM Part Numbers
* Vw: 038 198 141 EX
* Audi: 06C 198 141 AXIMG_4079.JPG
