#1 Skrevet Oktober 6, 2017 Noen som vet hvordan man kan resette girmønster på zf5hp24a som sitter i a6/8 etter overhaling? Finner ikke igjen det jeg leste på nettet en plass tidligere Sent from my iPhone using Tapatalk 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#2 Skrevet Oktober 6, 2017 Basic Settings: Basic Settings should be performed on an Automatic Transmission after: Engine replacement . ECU replacement Throttle Valve adjustment TPS replacement TPS adustment TCM Replacement First, make sure there are no fault codes in the Auto Trans. Then, with the key in the on position, and engine OFF. Do not touch the accelerator pedal. [select] [02 - Auto Trans] [basic Settings - 04] Set Group to "000" [Go!] Press accelerator pedal all the way to the floor and count out loud 3 seconds. [Done, Go Back] Release the accelerator pedal. It is normal for there to be no explicit instructions or changes on the screen when you do the above procedure. The transmission controller does not provide any feedback that it has been successfully performed. For 09G transmissions, Basic Settings group 001 is used and the accelerator pedal is NOT touched. Note: In some newer Audi vehicles, you may find that Group 000 in Auto Trans. is unavailable. If that is the case, you should follow this procedure: First, make sure there are no fault codes in the Auto Trans. Then, with the key in the on position, and engine OFF. Do not touch the accelerator pedal. [select] [01 - Engine] [basic Settings - 04] Set Group to "063" [Go!] Press accelerator pedal all the way to the floor and count out loud 3 seconds. [Done, Go Back] Release the accelerator pedal. 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#3 Skrevet Oktober 8, 2017 Takk, skal prøve det i dag Sent from my iPhone using Tapatalk 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
