LØST 8P ESP-lampe og ukjent feilkode
Hei!
Sliter litt med a3n til dattra.
Har ESP-lampe, tenner når bilen starter. ABS-bremsene funker. Ingen andre lamper.
Legger ved feilkodene, sliter når det under ABS står 57344 - Unknown Error Code Unknown - 015
Forslag?
Saturday,11,August,2018,16:46:41:05031
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
http://www.Ross-Tech.com
VIN: WAUZZZ8P24A032819 License Plate:
Mileage: 199960km-124249mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56
VIN: WAUZZZ8P24A032819 Mileage: 199960km-124249miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Cannot be reached 1100
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine Labels: None
Part No: 06A 956 033 BB%
Component: SIMOS74 1.6l 7V 5312
Revision: 05000003 Serial number: AUX2Z0C5FNL023
Coding: 0001351
Shop #: WSC 06438 000 00000
VCID: 0A1C3A07652CEE6E03-805E
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 D
Component: ESP FRONT MK60 0102
Coding: 0051846
Shop #: WSC 06435 000 00000
VCID: 336287E35226CFA690-8066
3 Faults Found:
Unknown - 015 - - MIL ON
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 A HW: 8P0 820 043 A
Component: KlimavollautomatH11 0120
VCID: 2A5C9A8785EC8E6E23-807E
2 Faults Found:
01332 - Door Control Module; Passenger Side (J387)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 49
Mileage: 199968 km
Time Indication: 0
Date: 2017.12.09
Time: 17:17:37
Freeze Frame:
ON
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 254
Reset counter: 49
Mileage: 144889 km
Time Indication: 0
Date: 2012.09.30
Time: 14:16:26
Freeze Frame:
Temperature: 2.0°C
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H27 0401
Revision: 00000000 Serial number: 00000006616071
Coding: 0D8ECF0080141000000000000000000000
Shop #: WSC 00000 000 00000
VCID: 3B72AFC37A7607E648-806E
Subsystem 1 - Part No: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00055568
Shop #: WSC 00000
6 Faults Found:
00924 - Relay for Headlamp Cleaning System (J39)
009 - Open or Short to Ground
02396 - Parking Light Rear Left (M4)
012 - Electrical Fault in Circuit - Intermittent
01320 - Control Module for Climatronic (J255)
004 - No Signal/Communication - Intermittent
00466 - Control Module for Steering Column Electronics (J527)
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
Component: Airbag 8.4ED H01 0130
Coding: 0010602
VCID: 4586C93B0CB241162E-8010
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 007 0030
Coding: 0000012
VCID: 306888EFA330F4BEED-8064
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 930 D HW: 8P0 920 930 D
Component: KOMBIINSTR. VDO H25 0070
Revision: D04 Serial number: 2245CD04007173
Coding: 0004103
Shop #: WSC 00746 218 182587
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 00000011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 168401 km
Time Indication: 0
Date: 2015.01.06
Time: 08:11:43
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0070
Revision: 08 Serial number: 200010361667F8
Coding: 3D0F0342070100
VCID: 26446EB791F4AA0E07-8072
3 Faults Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 6
Reset counter: 89
Mileage: 199967 km
Time Indication: 0
Date: 2018.03.06
Time: 05:31:40
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 40
Reset counter: 49
Mileage: 199967 km
Time Indication: 0
Date: 2018.03.06
Time: 05:31:44
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 49
Mileage: 199967 km
Time Indication: 0
Date: 2018.03.08
Time: 16:21:24
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D04 Serial number: AUX7Z0C5FNI023
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H09 0010
Coding: 0000120
VCID: 397EB5CB704A35F65A-806C
2 Faults Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
00943 - Heated Exterior Mirror; Driver Side (Z4)
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 143 L
Component: EPS_ZFLS Kl.6 0402
1 Fault Found:
00750 - Warning Lamp
013 - Check DTC Memory - Intermittent
Freeze Frame:
Mileage: 6440 km
Temperature: 15.0°C
Voltage: 11.20 V
Voltage: 10.90 V
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 B
Component: KSG H02 0030
Coding: 008800186D288505484A016000
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH22 0080
Revision: 00000 Serial number: 10000001026313
VCID: 70E848EF63B0B4BEAD-8024
Address 52: Door Elect, Pass.
Cannot be reached
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 01:56)--------------------------
Møller tok ei grunninnstilling av alle sensorene i systemet, og borte ble lampen
