#1 Skrevet August 13, 2018 Hei! Sliter litt med a3n til dattra. Har ESP-lampe, tenner når bilen starter. ABS-bremsene funker. Ingen andre lamper. Legger ved feilkodene, sliter når det under ABS står 57344 - Unknown Error Code Unknown - 015 Forslag? Saturday,11,August,2018,16:46:41:05031 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 15.7.1.0 (x64) Data version: 20150904 http://www.Ross-Tech.com VIN: WAUZZZ8P24A032819 License Plate: Mileage: 199960km-124249mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8P (1K0) Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 VIN: WAUZZZ8P24A032819 Mileage: 199960km-124249miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: Cannot be reached 1100 56-Radio -- Status: Cannot be reached 1100 ------------------------------------------------------------------------------- Address 01: Engine Labels: None Part No: 06A 956 033 BB% Component: SIMOS74 1.6l 7V 5312 Revision: 05000003 Serial number: AUX2Z0C5FNL023 Coding: 0001351 Shop #: WSC 06438 000 00000 VCID: 0A1C3A07652CEE6E03-805E No Faults Found or DTCs not supported by controller or a communication error occurred ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No: 1K0 907 379 D Component: ESP FRONT MK60 0102 Coding: 0051846 Shop #: WSC 06435 000 00000 VCID: 336287E35226CFA690-8066 3 Faults Found: 57344 - Unknown Error Code Unknown - 015 - - MIL ON 57344 - Unknown Error Code Unknown - 015 - - MIL ON 57344 - Unknown Error Code Unknown - 015 - - MIL ON ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8P0-820-043.lbl Part No SW: 8P0 820 043 A HW: 8P0 820 043 A Component: KlimavollautomatH11 0120 Shop #: WSC 06435 000 00000 VCID: 2A5C9A8785EC8E6E23-807E 2 Faults Found: 01332 - Door Control Module; Passenger Side (J387) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 49 Mileage: 199968 km Time Indication: 0 Date: 2017.12.09 Time: 17:17:37 Freeze Frame: ON 01592 - Air Quality Sensor (G238) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 254 Reset counter: 49 Mileage: 144889 km Time Indication: 0 Date: 2012.09.30 Time: 14:16:26 Freeze Frame: Temperature: 2.0°C ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl Part No SW: 8P0 907 279 A HW: 8P0 907 279 A* Component: Bordnetz-SG 1.0 H27 0401 Revision: 00000000 Serial number: 00000006616071 Coding: 0D8ECF0080141000000000000000000000 Shop #: WSC 00000 000 00000 VCID: 3B72AFC37A7607E648-806E Subsystem 1 - Part No: 8P1 955 119 F Labels: 1KX-955-119.CLB Component: Wischer AU350 H10 0040 Coding: 00055568 Shop #: WSC 00000 6 Faults Found: 00924 - Relay for Headlamp Cleaning System (J39) 009 - Open or Short to Ground 02396 - Parking Light Rear Left (M4) 012 - Electrical Fault in Circuit - Intermittent 01332 - Door Control Module; Passenger Side (J387) 004 - No Signal/Communication 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication - Intermittent 00466 - Control Module for Steering Column Electronics (J527) 004 - No Signal/Communication - Intermittent 02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8P0-959-655-84.lbl Part No SW: 8P0 959 655 F HW: 8P0 959 655 F Component: Airbag 8.4ED H01 0130 Coding: 0010602 Shop #: WSC 06435 000 00000 VCID: 4586C93B0CB241162E-8010 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 A HW: 1K0 953 549 A Component: Lenksäulenmodul 007 0030 Coding: 0000012 Shop #: WSC 06435 000 00000 VCID: 306888EFA330F4BEED-8064 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl Part No SW: 8P0 920 930 D HW: 8P0 920 930 D Component: KOMBIINSTR. VDO H25 0070 Revision: D04 Serial number: 2245CD04007173 Coding: 0004103 Shop #: WSC 00746 218 182587 VCID: 336287E35226CFA690-8066 1 Fault Found: 00003 - Control Module 014 - Defective Freeze Frame: Fault Status: 00000011 Fault Priority: 1 Fault Frequency: 1 Reset counter: 255 Mileage: 168401 km Time Indication: 0 Date: 2015.01.06 Time: 08:11:43 ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb Part No SW: 1K0 907 530 B HW: 1K0 907 951 Component: Gateway H08 0070 Revision: 08 Serial number: 200010361667F8 Coding: 3D0F0342070100 Shop #: WSC 06435 000 00000 VCID: 26446EB791F4AA0E07-8072 3 Faults Found: 00470 - Company Comfort Databus in Single Wire 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 3 Fault Frequency: 6 Reset counter: 89 Mileage: 199967 km Time Indication: 0 Date: 2018.03.06 Time: 05:31:40 01304 - Radio 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 40 Reset counter: 49 Mileage: 199967 km Time Indication: 0 Date: 2018.03.06 Time: 05:31:44 01332 - Door Control Module; Passenger Side (J387) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 49 Mileage: 199967 km Time Indication: 0 Date: 2018.03.08 Time: 16:21:24 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 8P0 920 930 D HW: 8P0 920 930 D Component: KOMBIINSTR. VDO H25 0070 Revision: D04 Serial number: AUX7Z0C5FNI023 Shop #: WSC 00746 218 182587 VCID: 336287E35226CFA690-8066 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl Part No: 8P0 959 801 A Component: Tuersteuerger. H09 0010 Coding: 0000120 Shop #: WSC 06435 000 00000 VCID: 397EB5CB704A35F65A-806C 2 Faults Found: 00932 - Electric Window Motor; Drivers Side (V147) 005 - No or Incorrect Basic Setting / Adaptation - Intermittent 00943 - Heated Exterior Mirror; Driver Side (Z4) 012 - Electrical Fault in Circuit ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K1 909 143 L Component: EPS_ZFLS Kl.6 0402 Shop #: WSC 00000 000 00000 VCID: 336287E35226CFA690-8066 1 Fault Found: 00750 - Warning Lamp 013 - Check DTC Memory - Intermittent Freeze Frame: Mileage: 6440 km Temperature: 15.0°C Voltage: 11.20 V Voltage: 10.90 V ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8P0-959-433.lbl Part No: 8P0 959 433 B Component: KSG H02 0030 Coding: 008800186D288505484A016000 Shop #: WSC 06435 000 00000 VCID: 3B72AFC37A7607E648-806E Subsystem 1 - Component: Sounder n.mounted Subsystem 2 - Component: NGS n.mounted Subsystem 3 - Component: IRUE n.mounted 1 Fault Found: 01332 - Door Control Module; Passenger Side (J387) 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 47: Sound System Labels: 8Px-035-382.lbl Part No SW: 8P3 035 382 HW: 8P3 035 382 Component: AB2 SUBWOOFERBOXH22 0080 Revision: 00000 Serial number: 10000001026313 Shop #: WSC 00000 000 00000 VCID: 70E848EF63B0B4BEAD-8024 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Cannot be reached ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached End-------------------------(Elapsed Time: 01:56)-------------------------- 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#2 Skrevet August 14, 2018 Møller tok ei grunninnstilling av alle sensorene i systemet, og borte ble lampen 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
