hei!
har gått i innkjøp av en A6 Allroad, eid den i noen dager da jeg plutselig får "air suspension fault"  og noe høydejustering av lykter ( som sikker henger med luftjæringen)..
feilmeldingen gikk bort da jeg stoppet og startet bilen igjen.. men har 5 feil som la inn.
lurer på noen har noe tips hva feilene kan være?:
13 Adaptive Cruise Control
    System description: ACC3
    Software number: 4G0907561A
    Software version: 0410
    Hardware number: 4G0907561
    Hardware version: H19
    Serial number: 00000000000000
    ODX name: EV_AdaptCruisContrAU57X
    ODX version: 002010
    Long coding: 7F04010202
    Trouble codes:
        U111300 - Function limitation due to received malfunction value
            Passive
34 Ride Control System
    System description: LUFE-DAEMPFER
    Software number: 4G0907553F
    Software version: 0782
    Hardware number: 4G0907553F
    Hardware version: H18
    Serial number: ‰ f1
    ODX name: EV_AirSuspe
    ODX version: 003024
    Long coding: 008003
    Trouble codes:
        C104807 - Level control system sensor mechanical malfunction
            Passive
55 Headlight Regulation
    System description: ....LWR12....
    Software number: 4H0907357B
    Software version: 0010
    Hardware number: 4H0907357B
    Hardware version: H02
    Serial number: 140828-0004-0194
    ODX name: EV_HeadlRegulBasic
    ODX version: 005001
    Long coding: 11226F601002A300
    Trouble codes:
            Passive
5 On-Board Camera
    System description: DPC-SG
    Software number: 4G0907217A
    Software version: 0038
    Hardware number: 4H0907217A
    Hardware version: H27
    Serial number: 26213002542100000000381133
    ODX name: EV_OnBoardCamerDPC
    ODX version: 001007
    Long coding: EA060000
    Trouble codes:
            Passive
8E Image Processing Electronics
    System description: BV-SG
    Software number: 4G0907107E
    Software version: 0041
    Hardware number: 4H0907107
    Hardware version: H32
    Serial number: 00500012140814769100320000
    ODX name: EV_BC7
    ODX version: 001001
    Long coding: 04C0BA1C1111
    Trouble codes:
        C110800 - Function limitation due to missing image information
            Passive
Ser jo ut som en sensor som kødder litt. De koster vel litt over 3000kr stk..
Men jeg ser at et stort problem med disse sensorene er at kula på "armene" setter seg(ruster fast) og da er det gummi foringen som kula er pressa inn i som vrir seg istedenfor, dette blir feil og da vil ofte bilen bli skeiv eller få feilmeldinger fordi den ikke klarer å finne riktig høyde. Et tips er å ta av høyde sensorene og prøve å vri kula med ei tang så kula løsner og smøre dette opp igjen. Gummi foringen skal ikke vri seg , kun kula inni foringen som skal bevege på seg. Så hvis selve sensoren er i orden kan man spare 3000kr pr hjørne om man får løsnet og smurt opp disse kulene
Gratulerer med ny bil. Som sagt, ser det ut som det er en sensor som tuller.
Merket når jeg kjørte opp den fra dynamic til allroad første gang at det knirket og laget litt lyd, virket som den hadde stått i dynamic en liten stund..
kan det være dette som trigget sensor kanskje...?
når jeg søkte opp feilen så ser det ut som det er rear left, noen plass det kan bekreftes?
Det kan være da skaden sjedde. Tipper at det ikke får beveget nok på seg, og at det da ruster fast slik at den ikke får beveget seg slik den skal. Prøver den da å bevege seg mere en den klarer, knekker den istedenfor.
Er ikke sikkert den har knekt, men når den "foringen" vrir seg i armen så kan det komme kneppe lyder ,for den skal ikke vri seg egentlig. Jeg har vært borti at de har satt seg på to biler på veldig kort til nå på jobben. Akkurat samme feil på begge to. Ene var en touareg andre var en q7 akkurat samme system på begge to. Og akkurat det samme skjedde på min forrige Allroad C5. Som også har samme systemet. Billigere å kjøpe sånne senke stenger (gjenge stenger) og bytte armene,du trenger ikke senke .
Hei igjen!
fikk feilsøkt litt på verksted idag på denne, de fikk opp samme kode som meg..
de sa også det var en kjørehøydesensor, men at de ikke vet hvilken og trengte litt tid for feilsøking!
Noen vet hvor mange kjørehøydesensor det er? Er det en over hver hjul?
noen forlag for og evt finne «rett» sensor som tuller?
Mvh mads
Hei igjen!
Mvh mads
Eg har hatt lignande feil på min Touareg. Då brukte eg VagCom og las ut "live" verdiar på høgdesensorane. Den eine skilte seg ut med ustabile verdiar, og viste seg å være fuktighet i pluggen. Etter at eg rensa og tørka har det fungert fint😊
Okei, det må jeg prøve!
hvordan leser du av verdiene slik? :-)
Er ei lita stund sidan eg gjorde det, men meinar eg fant level control i "measuring blocks" og fikk lest ut verdiane der😊
