#1 Skrevet Juni 1, 2019 hei! har gått i innkjøp av en A6 Allroad, eid den i noen dager da jeg plutselig får "air suspension fault" og noe høydejustering av lykter ( som sikker henger med luftjæringen).. feilmeldingen gikk bort da jeg stoppet og startet bilen igjen.. men har 5 feil som la inn.  lurer på noen har noe tips hva feilene kan være?: 13 Adaptive Cruise Control   System description: ACC3            Software number: 4G0907561A    Software version: 0410   Hardware number: 4G0907561     Hardware version: H19   Serial number: 00000000000000   ODX name: EV_AdaptCruisContrAU57X   ODX version: 002010   Long coding: 7F04010202   Trouble codes:        U111300 - Function limitation due to received malfunction value           Passive 34 Ride Control System   System description: LUFE-DAEMPFER   Software number: 4G0907553F    Software version: 0782   Hardware number: 4G0907553F    Hardware version: H18   Serial number: ‰ f1   ODX name: EV_AirSuspe   ODX version: 003024   Long coding: 008003   Trouble codes:        C104807 - Level control system sensor mechanical malfunction           Passive 55 Headlight Regulation   System description: ....LWR12....   Software number: 4H0907357B    Software version: 0010   Hardware number: 4H0907357B    Hardware version: H02   Serial number: 140828-0004-0194     ODX name: EV_HeadlRegulBasic   ODX version: 005001   Long coding: 11226F601002A300   Trouble codes:        U111300 - Function limitation due to received malfunction value           Passive 5 On-Board Camera   System description: DPC-SG          Software number: 4G0907217A    Software version: 0038   Hardware number: 4H0907217A    Hardware version: H27   Serial number: 26213002542100000000381133   ODX name: EV_OnBoardCamerDPC   ODX version: 001007   Long coding: EA060000   Trouble codes:        U111300 - Function limitation due to received malfunction value           Passive8E Image Processing Electronics   System description: BV-SG           Software number: 4G0907107E    Software version: 0041   Hardware number: 4H0907107     Hardware version: H32   Serial number: 00500012140814769100320000   ODX name: EV_BC7   ODX version: 001001   Long coding: 04C0BA1C1111   Trouble codes:        C110800 - Function limitation due to missing image information           Passive  0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#2 Skrevet Juni 1, 2019 Ser jo ut som en sensor som kødder litt. De koster vel litt over 3000kr stk..  Men jeg ser at et stort problem med disse sensorene er at kula på "armene" setter seg(ruster fast) og da er det gummi foringen som kula er pressa inn i som vrir seg istedenfor, dette blir feil og da vil ofte bilen bli skeiv eller få feilmeldinger fordi den ikke klarer å finne riktig høyde. Et tips er å ta av høyde sensorene og prøve å vri kula med ei tang så kula løsner og smøre dette opp igjen. Gummi foringen skal ikke vri seg , kun kula inni foringen som skal bevege på seg. Så hvis selve sensoren er i orden kan man spare 3000kr pr hjørne om man får løsnet og smurt opp disse kulene 1 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#3 Skrevet Juni 1, 2019 Gratulerer med ny bil. Som sagt, ser det ut som det er en sensor som tuller. 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#4 Skrevet Juni 1, 2019 (endret) Merket når jeg kjørte opp den fra dynamic til allroad første gang at det knirket og laget litt lyd, virket som den hadde stått i dynamic en liten stund..  kan det være dette som trigget sensor kanskje...?  når jeg søkte opp feilen så ser det ut som det er rear left, noen plass det kan bekreftes? 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#5 Skrevet Juni 1, 2019 Det kan være da skaden sjedde. Tipper at det ikke får beveget nok på seg, og at det da ruster fast slik at den ikke får beveget seg slik den skal. Prøver den da å bevege seg mere en den klarer, knekker den istedenfor. 1 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#6 Skrevet Juni 1, 2019 Er ikke sikkert den har knekt, men når den "foringen" vrir seg i armen så kan det komme kneppe lyder ,for den skal ikke vri seg egentlig. Jeg har vært borti at de har satt seg på to biler på veldig kort til nå på jobben. Akkurat samme feil på begge to. Ene var en touareg andre var en q7 akkurat samme system på begge to. Og akkurat det samme skjedde på min forrige Allroad C5. Som også har samme systemet. Billigere å kjøpe sånne senke stenger (gjenge stenger) og bytte armene,du trenger ikke senke . 1 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#7 Skrevet Juni 12, 2019 (endret) Hei igjen! fikk feilsøkt litt på verksted idag på denne, de fikk opp samme kode som meg.. de sa også det var en kjørehøydesensor, men at de ikke vet hvilken og trengte litt tid for feilsøking! Noen vet hvor mange kjørehøydesensor det er? Er det en over hver hjul? noen forlag for og evt finne «rett» sensor som tuller?  Mvh mads 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#8 Skrevet Juni 16, 2019 Anonymisert for gjester og medlemmer uten abonnement På 12.6.2019 den 15.42, Mads Kringen skrev: Hei igjen! fikk feilsøkt litt på verksted idag på denne, de fikk opp samme kode som meg.. de sa også det var en kjørehøydesensor, men at de ikke vet hvilken og trengte litt tid for feilsøking! Noen vet hvor mange kjørehøydesensor det er? Er det en over hver hjul? noen forlag for og evt finne «rett» sensor som tuller?  Mvh mads Eg har hatt lignande feil på min Touareg. Då brukte eg VagCom og las ut "live" verdiar på høgdesensorane. Den eine skilte seg ut med ustabile verdiar, og viste seg å være fuktighet i pluggen. Etter at eg rensa og tørka har det fungert fint😊  1 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#9 Skrevet Juni 16, 2019 Anonymisert for gjester og medlemmer uten abonnement 12 minutter siden, Jørn Skår skrev: Eg har hatt lignande feil på min Touareg. Då brukte eg VagCom og las ut "live" verdiar på høgdesensorane. Den eine skilte seg ut med ustabile verdiar, og viste seg å være fuktighet i pluggen. Etter at eg rensa og tørka har det fungert fint😊  Okei, det må jeg prøve! hvordan leser du av verdiene slik? :-) 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#10 Skrevet Juni 16, 2019 Er ei lita stund sidan eg gjorde det, men meinar eg fant level control i "measuring blocks" og fikk lest ut verdiane der😊 1 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
