#1 Skrevet September 1, 2019 (endret) Hei, Jeg selger min mye påkostede A4, prisantydning 99 000. Bilder Build spec: AEB head /w oversize Ferrea valves, springs & ARP bolts IE Adjustable cam gear, manual tensioner + dual dowel pin kit Cat cams 3658's 83mm JE 8.5:1 CR Eurospec 92.8mm forged knife edged crank Scat rods w/ 20mm wrist pin TFSI coil conversion B6S4 MAF sensor ER Comp FMIC + custom charge piping SEM big port intake manifold + 75mm R32 TB ID1000 injectors + Bosch 005 fuel pump PSi T25 manifold EFR6758 3" DP > race cat > Ferrita stainless exhaust Sport suspension B6 S4 brakes front and rear ClutchMasters FX850 twin disc clutch Neste frist for godkjent EU-kontroll 08.05.2021. Ta kontakt på hans.marius at torgersen.com hvis du er interessert. Med vennlig hilsen, Hans Marius Torgersen 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#2 Skrevet September 1, 2019 Anonymisert for gjester og medlemmer uten abonnement 2 timer siden, Hans Marius Torgersen skrev: Hei, Jeg selger min mye påkostede A4, prisantydning 99 000. Bilder Build spec: AEB head /w oversize Ferrea valves, springs & ARP bolts IE Adjustable cam gear, manual tensioner + dual dowel pin kit Cat cams 3658's 83mm JE 8.5:1 CR Eurospec 92.8mm forged knife edged crank Scat rods w/ 20mm wrist pin TFSI coil conversion B6S4 MAF sensor ER Comp FMIC + custom charge piping SEM big port intake manifold + 75mm R32 TB ID1000 injectors + Bosch 005 fuel pump PSi T25 manifold EFR6758 3" DP > race cat > Ferrita stainless exhaust Sport suspension B6 S4 brakes front and rear ClutchMasters FX850 twin disc clutch Neste frist for godkjent EU-kontroll 08.05.2021. Ta kontakt på hans.marius at torgersen.com hvis du er interessert. Med vennlig hilsen, Hans Marius Torgersen Bildelinken funker ikke? 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#3 Skrevet September 1, 2019 Prøver igjen.. https://1drv.ms/u/s!Aswf3iICPZdNgpYVhE56Olbrsz7dew?e=ifpjjN 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#4 Skrevet September 1, 2019 Anonymisert for gjester og medlemmer uten abonnement 25 minutter siden, Hans Marius Torgersen skrev: Prøver igjen.. https://1drv.ms/u/s!Aswf3iICPZdNgpYVhE56Olbrsz7dew?e=ifpjjN Får fortsatt beskjed om å logge på onedrive. Du kan laste opp bilder rett på forumet evnt. 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#5 Skrevet September 1, 2019 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#6 Skrevet September 24, 2019 Ny prisantydning 85000 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#7 Skrevet September 27, 2019 Har du noen bilder av motorrom? Hvor originalt ser det ut nedi der? tenkte på til EU kontroll osv. Er senk godkjent i vognkort? 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#8 Skrevet September 29, 2019 Hei, Det er det originale sportsunderstellet som bilen ble kjøpt med.. Her er noen bilder av motorrom.. Det bør være mulig å få det til å se mer originalt ut med noen deksler. Det følger med en motor til også. Sommerfelger er felger på bildene, vinterfelger ligner B5 RS4 felgene. 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#9 Skrevet November 7, 2019 Solgt 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
