2009 mod tiguan: Hjelp til koding av ABS unit!
Hei!
Skiftet håndbreks modul uten og ta autoscan på forhånd, så mistet selvfølgelig koden på abs modulen... Noen som har mulighet til og finne den med odis elns?
Se auto-scan: (etter modul bytte. er kun abs modulen igjen.)
Sunday,11,August,2019,21:43:49:39058
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.0.4 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WVGZZZ5NZ9W044424   License Plate: SU70439 RUBEN
Mileage: 171660km-106664mi   Repair Order:
Chassis Type: 5N (1K0)
Scan: 01 03 08 09 10 15 16 17 18 19 22 25 37 42 44 46 52 53 56 62
          69 72
VIN: WVGZZZ5NZ9W044424   Mileage: 171660km-106664miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 997 016 K    HW: 03L 906 022 G
   Component: R4 2.0l TDI 0000SG  9979
   Revision: 13H01---    Serial number: VWX7Z0H83NB11H
   Coding: 0000172
   Shop #: WSC 27426 002 1048576
   VCID: 3A70806A75C70B9F99-806E
1 Fault Found:
053271 - Please Check Fault Codes in Control Module for ABS Brakes
               U1017 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 171653 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:01:28
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.16 V
                    Torque: 219.0 Nm
                    Hex Value: 0xFF00
                    Bin. Bits: 00000010
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
   Part No SW: 5N0 614 517 L    HW: 5N0 614 517 L
   Component: J104    C2 450 V2   0006
   Revision: --H12---    Serial number: 00000001445509
   Coding: 0014623
   Shop #: WSC 01324 785 00200
   VCID: 3776995E46D516F766-8062
2 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 252
                    Mileage: 171660 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 02:18:16
             Freeze Frame:
                    Speed: 54.0 km/h
                    Hex Value: 0x0140
                    Voltage: 14.00 V
                    Bin. Bits: 00011111
                    Count: 243
                    Hex Value: 0x0000
01044 - Control Module Incorrectly Coded
            000 - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 252
                    Time Indication: 0
             Freeze Frame:
                    Speed: 0.0 km/h
                    Hex Value: 0x0000
                    Voltage: 1.75 V
                    Bin. Bits: 00011111
                    Count: 165
                    Hex Value: 0x0000
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 DA    HW: 1K0 907 044 DA
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 69D20F2640E1700720-803C
No fault code found.
Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
   Part No SW: 3C8 937 049 E    HW: 3C8 937 049 E
   Component: Bordnetz-SG     H54 2602
   Revision: 00H54000    Serial number: 00000008869364
   Coding: ED8A8FA300041C0047190000140000000009FF475C400124390000000000
   VCID: 336EAD4E52ADFAD75A-8066
   Subsystem 1 - Part No: 5N1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 050908  012 0203
   Coding: 00038805
   Shop #: WSC 01324
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     150908 046  0204
   Coding: 00208933
   Shop #: WSC 01324
Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
   Part No SW: 1T0 919 475 C    HW: 1T0 919 475
   Component: PARKHILFE PLA H07 0009
   Revision: --------    Serial number: 61730824904464
   Coding: 100002
   VCID: 3B7E856EBAFD329782-806E
1 Fault Found:
01316 - ABS Control Module
            013 - Check DTC Memory - Intermittent
             Freeze Frame:
                    Fault Status: 00101101
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 37
                    Mileage: 171653 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:01:24
             Freeze Frame:
                    Temperature: 18.0°C
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 5N0 959 655 A    HW: 5N0 959 655 A
   Component: J234__200 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DPJ0PTZT
   Coding: 0012336
   Shop #: WSC 01324 020 00200
   VCID: 3B7E856E7AFD329782-806E
   Subsystem 1 - Serial number: 6333FTS666072318
   Subsystem 2 - Serial number: 6343FTS650442318
   Subsystem 3 - Serial number: 6353ETS6SE7PU5KR
   Subsystem 4 - Serial number: 6363ETS68ILOUVNP
   Subsystem 5 - Serial number: 00000000000000000
   Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BN    HW: 1K0 953 549 BN
   Component: J0527           752 0101
   Coding: 0000012
   VCID: 7F06B17E2E65EEB7EE-802A
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 5N0 920 870 D    HW: 5N0 920 870 D
   Component: KOMBIINSTRUMENT VDD 2420
   Revision: V0004000    Serial number: VWX7Z0H83NB11H
   Coding: 0007104
   Shop #: WSC 00011 888 06946
   VCID: 3162A746A8B1C8C728-8064
Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 5K0 963 271 D
   Component: Zuheizer        051 2706
   Revision: 00051000    Serial number: 09021535000000
   Coding: 0000011
   Shop #: WSC 00160 218 61663
   VCID: 3064A242A3BBC1CF27-8064
Address 19: CAN Gateway        Labels:. 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 Q    HW: 1K0 907 951
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 030908F1001522
   Coding: F9A27F46400A026002
   Shop #: WSC 00160 218 68038
   VCID: 356A93565CD9E4E774-8060
Address 22: AWD        Labels: 0AY-907-554-V1.clb
   Part No SW: 0AY 907 554 C    HW: 0AY 907 554 C
   Component: Haldex 4Motion      0041
   Coding: 0000005
   VCID: 4B9ED5AE2A5D821732-801E
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 2420
Address 37: Navigation        Labels: 1K0-035-191.lbl
   Part No SW: 1K0 035 191 D    HW: 1K0 035 191 D
   Component: J401                0350
   Revision: 00021000    Serial number: VWZ1Z2H8244899
   Coding: 0041402
   VCID: 234E5D0EE24D6A57AA-8076
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MAX3.clb
   Part No SW: 5N0 959 701 A    HW: 5N0 959 701 A
   Component: Tuer-SG         006 1205
   Coding: 0000190
Address 44: Steering Assist        Labels: 5N1-909-144.clb
   Part No SW: 5N1 909 144 G    HW: 5N1 909 148 E
   Component: J500__APA-BS KL.097 0401
   Revision: 1AH01251    Serial number: 00081780073802
   Coding: 0000258
   VCID: 3668945A41DFEFFF7D-8062
Address 46: Central Conv.        Labels:. 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0205
   Revision: 00020000    Serial number: 00000000000000
   Coding: 80800A0052830C7F3F04840560084F0BE0FC00
   VCID: 030E3D8E428D8A578A-8056
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
1 Fault Found:
00332 - Control Circuit for Tank Flap
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00110111
                    Fault Priority: 4
                    Fault Frequency: 4
                    Reset counter: 37
                    Mileage: 170749 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:51:01
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MAX3.clb
   Part No SW: 5N0 959 702 A    HW: 5N0 959 702 A
   Coding: 0000190
   VCID: 346CAE5257A3FDEF43-8060
Address 53: Parking Brake        Labels: 3AA-907-801.clb
   Part No SW: 3AA 907 801 H    HW: 3AA 907 801 H
   Component: J540 EPB4  VW-86594 0010
   Revision:   H19       Serial number: 00000001030226
   Coding: 0023057
   Shop #: WSC 00020 790 00000
Address 56: Radio        Labels: 1K0-035-191.lbl
   Component: R                   0350
   Coding: 0041402
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 5N0 959 703     HW: 5N0 959 703
   Component: Tuer-SG         006 1301
   Coding: 0000144
   Shop #: WSC 01324 785 1012552
   VCID: 74EC6E521723BDEF83-8020
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 D    HW: 1K0 907 383 B
   Component: Anhaenger     H15 0070
   Revision: 3A002001    Serial number: 00000108690849
   Coding: 0100000200000000
   VCID: 2E58BC3A798FD73F35-807A
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 5N0 959 704     HW: 5N0 959 704
   Coding: 0000144
   VCID: 75EA53561C59A4E7B4-8020
End-------------------------(Elapsed Time: 02:33)--------------------------
