#1 Skrevet November 30, 2019 Hei. Har en caddy 2.0 tdi 110hk 2012 som har stått ett par mnd. Var helt strømtom, når jeg fikk ladet den opp og begynte å kjøre begynte glødelampa å blinke og bilen gikk i nødmodus etter bare ett par hundre meter. Fikk disse feilkodene: Address 01: Engine Labels: 03L-906-018-CFF.clb Control Module Part Number: 03L 906 018 NJ HW: 03L 907 309 R Component and/or Version: R4 2.0l TDI H25 9977 Software Coding: 0019001A040600080000 Work Shop Code: WSC 00680 218 00000 ASAM Dataset: EV_ECM20TDI01103L906018NJ 003005 (VN35) ROD: EV_ECM20TDI01103L906018ET_VW36.rod VCID: 7F0B797DE64DDEB7DE-802A 5 Faults Found: 5171 - Boost Pressure Regulation P0299 00 [101] - Control Range Not Reached Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 89171 km Date: 2083.14.07 Time: 22:18:24 Engine speed: 2352.50 /min Normed load value: 99.6 % Vehicle speed: 33 km/h Coolant temperature: 26 °C Intake air temperature: -2 °C Ambient air pressure: 950 mbar Voltage terminal 30: 14.440 V Unlearning counter according OBD: 40 Charge Pressure Actuator: activation: 86.04 % Charge Pressure Actuator: acknowledgment: 86.44 % Charge air pressure specified value: 2296 hPa Accelerator pedal travel: 100.00 % Air mass: actual value (mg/stroke): 322.3 mg/stroke 5169 - Manifold Pressure / Boost Sensor (G31) P0238 00 [032] - Signal too High Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 89170 km Date: 2000.00.00 Time: 00:00:00 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 22 °C Intake air temperature: -40 °C Ambient air pressure: 990 mbar Voltage terminal 30: 11.860 V Unlearning counter according OBD: 39 Charge air pressure: actual value: 3000 hPa Engine status: COENG_READY Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1 5282 - Intake Air Temp. Sensor (G42) P0113 00 [032] - Signal too High Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 89170 km Date: 2080.14.11 Time: 20:37:49 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 22 °C Intake air temperature: -40 °C Ambient air pressure: 990 mbar Voltage terminal 30: 11.840 V Unlearning counter according OBD: 39 Exh.gas temp.sen 4: 18.8 °C 5290 - Throttle Actuator Control Circuit P2100 00 [032] - Open Circuit Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 89170 km Date: 2000.00.00 Time: 00:00:00 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 22 °C Intake air temperature: -40 °C Ambient air pressure: 990 mbar Voltage terminal 30: 12.200 V Unlearning counter according OBD: 39 Air mass: actual value (mg/stroke): 0.0 mg/stroke Throttle valve adapter: specified value: 100.00 % Throttle valve adapter: actual value: 100.00 % Throttle valve adapter: offset closed: -0.07 % Throttle valve adapter: status-Bits 0-7: 0 Throttle valve adapter: status-Bits 0-7: 54 Throttle valve adapter: status-Bits 0-7: 11 Throttle valve adapter: status-Bits 0-7: 18 Throttle valve adapter: uncond voltage actual value: 4999.8 mV 5305 - Throttle Position Sensor (G69) P0123 00 [032] - Signal too High Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 89170 km Date: 2000.00.00 Time: 00:00:00 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 22 °C Intake air temperature: -40 °C Ambient air pressure: 990 mbar Voltage terminal 30: 12.220 V Unlearning counter according OBD: 39 Air mass: actual value (mg/stroke): 0.0 mg/stroke Throttle valve adapter: specified value: 0.00 % Throttle valve adapter: actual value: 100.00 % Throttle valve adapter: offset closed: -0.07 % Throttle valve adapter: status-Bits 0-7: 0 Throttle valve adapter: status-Bits 0-7: 54 Throttle valve adapter: status-Bits 0-7: 8 Throttle valve adapter: status-Bits 0-7: 2 Throttle valve adapter: uncond voltage actual value: 4999.8 mV Jeg slettet feilkoder og alt ble bra igjen. Kjørte et par hundre meter så kom glødelampa igjen med da bare med denne feilkoden: Address 01: Engine Labels: 03L-906-018-CFF.clb Control Module Part Number: 03L 906 018 NJ HW: 03L 907 309 R Component and/or Version: R4 2.0l TDI H25 9977 Software Coding: 0019001A040600080000 Work Shop Code: WSC 00680 218 00000 ASAM Dataset: EV_ECM20TDI01103L906018NJ 003005 (VN35) ROD: EV_ECM20TDI01103L906018ET_VW36.rod VCID: 7F0B797DE64DDEB7DE-802A 1 Fault Found: 5171 - Boost Pressure Regulation P0299 00 [167] - Control Range Not Reached MIL ON - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 89173 km Date: 2083.14.08 Time: 18:25:49 Engine speed: 2130.00 /min Normed load value: 99.6 % Vehicle speed: 29 km/h Coolant temperature: 20 °C Intake air temperature: -6 °C Ambient air pressure: 960 mbar Voltage terminal 30: 14.440 V Unlearning counter according OBD: 40 Charge Pressure Actuator: activation: 95.23 % Charge Pressure Actuator: acknowledgment: 95.25 % Charge air pressure specified value: 2284 hPa Accelerator pedal travel: 100.00 % Air mass: actual value (mg/stroke): 331.5 mg/stroke noen som har noen tips til hva som kan være galt? Klarer liksom ikke lese ut hva problemet er. 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
#2 Skrevet Desember 3, 2019 mulig dette er til hjelp. http://wiki.ross-tech.com/wiki/index.php/16683/P0299/000665 0 Del dette innlegget Lenke til innlegg Del på andre sider Flere delingsalternativer...
