VR6 12v turbo 288° kammer og justerbare drev
VR6 12v turbo 288° kammer med Don Octane justerbare drev.
Benket oppunder 1000hk i motor med disse.
8000,-
Ta gjerne kontakt om du lurer på noe : )
Fra produsent:
Techtonics VR6 288° RACE hydraulic camshaft set. Not for standard engines. Chilled hardened billets. #109 082S HD Valve Springs Required. Titanium Retainers recommend. Includes #832 250 VR6 Cam Locking Plate. (246° duration @.050″, .455″ lift) Valve/Piston and Retainer/Stem Seal clearance must be check!. Also recommended to replace the cam bolts #109 043. These also can be used with solid lifter. (use valve guide 109 230R)
20241107_222255.thumb.jpg.25319f8d525824ea1557eec1bb0cbcc5.jpg20241107_222227.thumb.jpg.1da45cf858d7a34bbe367934be7b388e.jpg20241107_222130.thumb.jpg.1901ca0660dab9edfd2f95469a046032.jpg
