Feilkode / MIL sensorfeil eksos?
Hei, :D
Fikk opp motorlampe på Audi A4 Quattro 2,0TDI CAHA Motor.
Sjekket med vagcom og var noen feilkoder på eksos diff trykk sensorer.
Slettet disse men kom tilbake igjen etter kort tid. (Heldigvis lenge nok til å passere EU-kontroll) : rock :
Noen tips til hvor begynne med disse, og delenr om sensoren sikter?
Kan det være tett DPF?
Kodene er følgende:
                Address 01: Engine       Labels: 03L-906-019-CAG.clb
Control Module Part Number: 03L 906 022 RM    HW: 03L 906 019 AL
  Component and/or Version: R4 2.0l TDI   X22 9978
           Software Coding: 1219401A243603080000
            Work Shop Code: WSC 26214 051 00000
              ASAM Dataset: EV_ECM20TDI03L906022RM A02008 (AU48)
                       ROD: EV_ECM20TDI03L906022NP.rod
                      VCID: 015F78D0D18417E250D-8054
6 Faults Found:
7140 - Function Restriction due to Faults in Other Modules
          U1113 00 [00101000] - -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 14
                    Mileage: 185910 km
                    Date: 2024.09.08
                    Time: 14:49:31
                    Engine RPM: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 75 °C
                    Intake air temperature: 30 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 13.380 V
                    Unlearning counter according OBD: 37
                    Cruise Control System (CCS): switch position-Bits 0-7: 129
                    CCS status-Bits 0-7: 45
                    Cr Ctl st Sh Off Irv Lst-Bits 0-7: 255
                    Cr Ctl st Sh Off Rv Lst-Bits 0-7: 255
                    Cr Ctl v Des Dspl: 0.00 km/h
                    Sig Reset Env x Id-Bits 0-7: 0
                    Cr Ctl st Shut Offirev-Bits 0-7: 0
4914 - Particulate Filter; Differential Pressure Sensor
          P2453 00 [11101000] - Implausible Signal
          MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Mileage: 185643 km
                    Date: 2024.09.06
                    Time: 14:45:38
                    Engine RPM: 2023.00 /min
                    Normed load value: 49.8 %
                    Vehicle speed: 67 km/h
                    Coolant temperature: 77 °C
                    Intake air temperature: 19 °C
                    Ambient air pressure: 1010 mbar
                    Voltage terminal 30: 14.500 V
                    Unlearning counter according OBD: 40
                    Exhaust gas vol.flow particulate filter: 224.1 m³/h
                    Surface temperature of filter: 351.3 °C
                    Field regeneration status-Bits 0-7: 0
                    Particle filter: difference pressure: -67 hPa
                    DPF: offset for differential pressure: 12 hPa
                    Exhaust gas temp.after pre-catalyst: 331.4 °C
                    Particle filter: kilometers since last regeneration: 0 m
12307 - Particulate Trap Bank 1
          P2002 00 [01100101] - Efficiency Below Threshold
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 186246 km
                    Date: 2024.09.11
                    Time: 17:18:07
                    Engine RPM: 2226.00 /min
                    Normed load value: 45.5 %
                    Vehicle speed: 96 km/h
                    Coolant temperature: 79 °C
                    Intake air temperature: 25 °C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 14.460 V
                    Exhaust gas vol.flow particulate filter: 245.1 m³/h
                    Particle filter: difference pressure: 47 hPa
                    DPF: offset for differential pressure: 49 hPa
                    Exhaust gas temp.after pre-catalyst: 355.4 °C
                    Particle filter: oil ash volume: 0.13 l
5253 - Particulate Filter; Differential Pressure Sensor
          P2452 00 [00100000] - Elect. Malfunction
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 17
                    Mileage: 184959 km
                    Date: 2024.08.25
                    Time: 19:19:02
                    Engine RPM: 831.50 /min
                    Normed load value: 41.2 %
                    Coolant temperature: 67 °C
                    Intake air temperature: 27 °C
                    Ambient air pressure: 980 mbar
                    Voltage terminal 30: 12.980 V
                    Unlearning counter according OBD: 24
                    Exhaust gas vol.flow particulate filter: 50.5 m³/h
                    Surface temperature of filter: 86.3 °C
                    Particle filter: difference pressure: 989 hPa
                    DPF: offset for differential pressure: 26 hPa
                    Exhaust gas temp.after pre-catalyst: 115.7 °C
5262 - Particulate Filter; Differential Pressure Sensor
          P2454 00 [00101000] - Short to GND
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 204
                    Mileage: 185630 km
                    Date: 2024.09.06
                    Time: 12:35:22
                    Engine RPM: 2044.50 /min
                    Normed load value: 15.3 %
                    Vehicle speed: 50 km/h
                    Voltage terminal 30: 13.580 V
                    Exhaust gas vol.flow particulate filter: 116.4 m³/h
                    Surface temperature of filter: 290.2 °C
                    Particle filter: difference pressure: -68 hPa
                    DPF: offset for differential pressure: 13 hPa
                    Exhaust gas temp.after pre-catalyst: 269.3 °C
5162 - Particulate Filter; Differential Pressure Sensor
          P2453 00 [01100000] - Implausible Signal
Readiness: 1 2 0 0 0
