Audi C4 - S4. GTO Wesbank Modified
History
As close to a GTO car as we will ever own. As the factory crushed three of the five original GTO cars some time after the close of the season. The remaining two are in Factory hands and not for sale. However one of the cars #5 was sent to Audi Sport South Africa in 1990 to develop Audi South Africas next generation Wesbank Modified car, The S4. The Audi 80/90 body of the GTO car not being sold in South Africa could not just be raced as the 200 Trans Am was. So Audi Sport SA undertook the project to build an S4 GTO car. The car is basically a GTO car in S4 body work.
We bought the car from Ashley Landman of Ashleys fine cars in Cape town South Africa in 2000.
Specifications
Cylinders 5 Inline
Displacement 2190 cc
Bore and Stroke 81mm x 85mm
Torque 720 Nm at 6000rpm
Output 720bhp at 7500 rpm
Number of Valves 20
Drive Permanent four-wheel drive
Clutch Twin dry plate
Number of Gears 6
Brakes Ventilated discs, 330mm front and rear
Suspension Double-wishbone at front and rear
Steering Power-assisted
Tyres Goodyear 25.5 x 14 x 17
Length 4800 mm
Width 2000 mm
Height 1221 mm
Wheelbase 2537 mm
Track 1680 mm front, 1680 mm rear
Weight 1206 kg
First Race Miami, March 5, 1989
Hentet herfra: http://eurospecsport.com/s4-gto.html
Gammel tråd, ufortjent lite respons! :tilber:
Värfår,värfår!!!?? hehe:tilber: :tilber: :tilber: :tilber:
Det har du jaggu helt rett i!
Hm, noen har jobba for å få en S4 ned i 1200 kg.....
Noen som vet hvor lett en S4 kan bli dersom man hiver ut alt uvesentlig?
Er bare en måte å finne det ut på det :P En gal Svenske driver på å skal få en S2 coupe ned i under 1000 kg !!!! : faint : Tror det krever en del karbon for å si det slik. Bakluke,dører,skjermer osv osv osv. Plexi-vinduer av tynneste sort.....listen kan gjøres lang. ;)
Bildet er blitt vist før, og viser utmerket godt hvor enkelt man får en "S4" på slankefarmen:
He He trur eg hadde lurt godt vist eg hadde fått den inn på verkstede
