Video: Audi R8 i bakkeløp
En video av en Audi R8 i et bakkeløp.
Merk den "greie" akselerasjonen...
http://testudladry.free.fr/jcc_videos2005/2005_gemenos_castellana.wmv
(10mb)
Litt om Audi R8: (kopiert fra denne tråden)
Info:
2001-2004 Audi R8 Specifications
Layout: Mid-engine, rear-wheel drive
Monocoque: Carbon fiber and aluminum honeycomb monocoque
Engine: V8, turbo-charged, 90 degree cylinder angle, 4 valves per cylinder, 2 Garrett turbo-chargers; to comply with the rules 2 x air restrictors, and boost pressure restriction to 1.67 bars (absolute), direct fuel injection, FSI
Engine management: Bosch MS 2.8 ('03)
Bosch MS 2.9 ('04)
Engine lubrication: Dry sump, Shell Racing Oil SR
Displacement: 3600 cc
Horsepower: 625 hp ('01-'02)
550 hp ('03)
550+ hp ('04)
Torque: 553 lb-ft. @ 7500 rpm ('01-'02)
516+ lb-ft. ('04)
Gearbox: Sequential 6-speed sports gearbox built by Ricardo
Clutch: CFC clutch
Differential: Multiple-disc limited slip differential
Driveshafts: Constant-velocity plunging tripod joint
Steering: Power-assisted rack-and-pinion steering
Suspension: Independent suspension at front and rear. Double-wishbone suspension. Pushrod system with horizontal spring/damper unit, adjustable gas-filled shock absorbers
Brakes: Hydraulic dual-circuit brake system, monobloc light-alloy brake calipers, ventilated carbon fiber brake discs at front and rear, brake force distribution, driver adjustable
Wheels: O.Z. forged magnesium rims, Front: 13.5 x 18 inches, Rear: 14.5 x 18 inches
Tires: Michelin Radial, Front: 33/65-18, Rear: 36/71-18
Length: 4640 mm
Width: 2000 mm
Wheelbase: 2740 mm
Front Overhang: 900 mm
Rear Overhang: 1010 mm
Weight: 911 kgs ('01 Le Mans average)
909 kgs ('02 Le Mans average)
919 kgs ('03 Le Mans average)
Tank capacity: 90 liters ('01-'03)
80 liters ('04)
: eek : : eek : All i want for christmas is an Audi R8 an Audi R8 an Audi R8. Dont give a damn about my two front teeth : smil : Fyttikatta for en aks da. Skulle likt å pellt av restriktorene på den R8en der : rock :
Dæven, dette var bil med hastverk!: eek :
Han skal sikkert hjem å rekke Grandisen som står i ovnen. Hehe,nei seriøst dette er faktisk råeste onboard-cam filmen jeg NOENSINNE har sett :tilber: :tilber: :tilber:
er det at filmen går litt for fort eller er den bilen bare helt syk?
Tror nok det bare er bilen som er helt syk ja... :tilber:
Er jo en grunn til at Audi R8 har vunnet alle tre pall-plassene med R8 de siste tre fire årene da :tilber:
denna gikk jo brukbart.
Var bratt på utsia av veien noen steder der ja. Best å holde seg på veien :P
Hihi var sørenmeg en BMW ja...
Man skal ikke tru allt man leser på internett :)
Jaja sånn kan det gå :)
Spinn syk. Tenk å fora litt turbo på dette.....nei! This is real power, no turbo shit! he he: rock :
R8 er jo enda verre enn denne her !!!! : eek : : eek : : eek :
Det der gikk jo bare no så inn i hampe ræva rått som Jan Erik Larsen ville sagt... Det var skikkelig sykhus å se på for å si det sånn: rock : : smil :
Saklig jeg hadde turt.... NOT:: :o
HEFTIG. A4 en er ikke så kjapp på turtall da den står i fri engang.
Dere hører vel forskjell på Audi og BMW, vel??:nana:
Enkleste er vel å se forskjell:nana:
Hva var det som fikk dere til å tro at dette var en R8 (rillene på skjermen)
"nesa" var alt for tynn samt rundt rattet. Fant dessverre ikke noen bilder bakfra men her er ihvertfall forfra.
