Søkte og fant:
Green - Twister Cold Air Intake
* Aluminum Housing acts as a heat shield
* Venture on top of the filter to speed the air up and remove the turbulence
* The dirt and dust is gathered on the inside of the shield for easy cleaning
* Bottom aluminum mount is equipped with velocity stack to ram air into the throttle body
lager ikke denne type filtrer en litt "spesiell" lyd under pådrag da? en slags hvine/suselyd?
