Hvilken feilkode er dette?
Hei, søkte med VAG-COM på audien, fikk opp følgende feilkode:
32547 - Unknown error code - 127-10 - Unknown error laboration - intermittent
Fant den ikke på de listene jeg fikk med.: gråter :
Hei
Her er eit svar fra Uwe Ross:
> Hello All,
> Fault Code on 1996 A4 1.8T Manual(AEB)MTM EPROM .
> 32547 Unknown Error Code
> 127-10 Unknown Error Elaboration Intermittent.
> Can anyone shed any light?
There's no way that's a "legitimate" fault code, the number is just too
far out of the range of normal fault codes. If this fault can be read
from your ECU in a reproducible, consistent way, I believe it's a bug in
your MTM chip, or possibly something proprietary that MTM has done.
> Also,can VAG COM be used to test the Boost Pressure
> Solenoid valve(between wastegate & turbo),if so whats
> the procedure?
You mean N75, the wastegate control solenoid? Depends what you mean
by "test". I'm pretty sure it's part of the Output Test sequence.
> One for Uwe, Are the A4/S4 Bentley CD's still backordered?
Yes. Complain at Bentley please..:-)
