trenger hjelp med feilkode!!
noen som kan forklare meg hva dette betyr???
Address 01: Engine
Controller: 895 907 551 A
Component: 2,2l MTM 270 PS HS D01
Coding: PMC 1
1 Fault Found:
00561 - Mixture Adaptation
15-10 - Adaptation Limit (Add) Not Reached - Intermittent
Readiness: N/A
http://forums.audiworld.com/vag/msgs/10751.phtml
Ser du har nummeret 15-10, og denne personen har 15-00 i feilmeldingen, men problemet ligger vel i samme gate så.
http://www.ross-tech.com/vag-com/cars/fuel-trim.html
"Add" means additive trim, which is addressing an imbalance at idle. When the ECU is using additive trim, it is telling the injectors to stay open a fixed amount longer or shorter. The malfunction (e.g. vacuum leak) becomes less significant as RPM increase. For additive adaptation values, the injection timing is changed by a fixed amount. This value is not dependent on the basic injection timing.
"Mult" mean multiplicative trim, which is addressing an imbalance at all engine speeds. The malfunction (e.g. clogged injector) becomes more severe at increased RPM. For multiplicative adaptation values, there is a percentage change in injection timing. This change is dependent on the basic injection timing.
Vakuumlekkasje?
