Leste i dag ut feilkoder med vag com pr en a4 b5 til en kompis pga varsel på display på instrumentpanel. rødt varsel: (!) og piper noen ganger. ikke noe mer info. blir også lys i den gule abs lampa på speedometeret..
VAG-COM Version: Release 512.4-UD
Thursday,14,December,2006,18:51:09
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine
Part No: 8D0 907 558 E
Component: 1.8L R4/5VT MOTR AT D03
Coding: 04051
Shop #: WSC 06335
2 Faults Found:
00515 - Camshaft Position (Hall) Sensor (G40)
29-10 - Short to Ground - Intermittent
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
Readiness: N/A
Address 02: Auto Trans
Part No: 8D0 927 156 BK
Component: AG5 01V 1.8l5VT RdW D70
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 08: Auto HVAC
Part No: 8L0 820 043 D
Component: A4 KLIMAVOLLAUTOMAT_D75
Coding: 04140
Shop #: WSC 06335
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
Skipping Address 15-Airbags
Address 17: Instruments
Part No: 8D0 919 880 N
Component: B5-KOMBIINSTR. VDO D10
Coding: 04142
Shop #: WSC 00000
Part No: IMMO
Component: IDENTNR: AUZ7Z0W0647385
IMMO-IDENTNR: AUZ7Z0W0647385
No fault code found.
Address 25: Immobilizer
Part No: Bit teA dre ss
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 35: Centr. Locks
Part No: 8L0 862 257 L
Component: ZV-Pumpe D10
Coding: 00000
Shop #: WSC 06335
1 Fault Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
End --------------------------------------------------------------------------------------------------
Trolig ingen av disse feilkodene som lager varsellampe?
hva betyr denne koden?:
kom ikke inn på abs modulen når jeg gikk direkte inn på denne.
"no response from controller!"
noen tips?
Tipper det er bremselysbryteren som lager krøll mht feillamper.
Men bremselysene viker. Fant litt info om den koden, måtte trå på bremsen før jeg leste ut koder. Det gjorde jeg ikke.
Hei ser du kjører en litt gammel versjon, sjekk ut Ross-tech og last ned 607.3
ellers så vil jeg anbefale denne linken http://wiki.ross-tech.com/index.php/Category:Fault_Codes her kan en se hva feilkoden muligens er!
00526 - Brake Light Switch (F): Circuit Malfunction
[edit]Possible Symptoms
MIL (Malfunction Indicator Light)
No Brake Lights
[edit]Possible Causes
Wiring and/or connections faulty between Brake Switch, Brake Lights and/or ABS Controle Module
Brake Light Switch (F) damaged
Brake Light faulty
Fuse(s) faulty
[edit]Possible Solutions
Check wiring and connections
Replace Brake Light Switch (F)
Check / Replace fuses(s)
Check / Replace Brake Lights
Check Brake Light Switch (F) in ABS Measuring Block
[edit]Special Notes
FAQ 2.7. Many Automatic Transmission Control Modules will show a DTC 00526 or 17087 that indicates a faulty brake light switch. This can be ignored and will not appear if you press the brakes once before checking for Fault Codes.
Retrieved from "http://wiki.ross-tech.com/index.php/00526"
Tor
No Brake Lights
Brake Light faulty
Fuse(s) faulty
[edit]Special Notes
Tor
Okei! Skal laste ned siste versjon å prøve på nytt å se om jeg kommer inn på abs modulen.
For ABS lampa lyser ikke den og sammen med det andre bemsetegnet ditt?
Edit: så at ABS lampa lyste og.
Da er grunnen til at du ikke får kontakt med ABS er pga den er def.
Er en svakhet på disse ABSene.
Går an å åpne disse og lodde den ledningen som har ryki.
Ikke en jobb for hvem som helst.
Hatt den feilen på min egen, men fikk lodda den etter noen forsøk.
Ja abs lyset lyser samtidig som det røde (!) tegnet i skjermen. Sitter abs modulen sammen med abs pumpa? Så det er inni abs modulen ledningene ryker og man kan lodde sammen?
ABS Hjernen er den svarte boksen som er skrudd fast i ABS pumpa ja.
Er inni ABS hjernen som to ledninger ryker av.
Er bare å lodde disse på igjen.
NB! det er himla smått inni der....må ha lupe for å se noen av leningen...så tynne er de.
Skjønner! Bruk å være smått med elektronikk : bh :
Er det mulig å ta abs hjernen fra abs pumpa slik at det blir enklere å lodde?
Ja...kan kjøre uten hjernen om du vil og.
Er skrudd fast med 6 torx skruer bare.
Litt trangt å komme til noen av de, men det går.
Da skal jeg prøve å ta den av en gang å se om jeg finner ut noe.
Tror det må være noe med modulen ettersom jeg ikke får kontakt med den med vag com. Ville jo fått kontakt med modulen selv om det er noe galt med en bremselysbryter vil jeg tro..
