Har lest av feil lageret med vag-com'en, og fikk ut denne loggen her:
VAG-COM Version: Release 303.1
Chassis Type: 8E - B6 Audi A4
Scan: 01,02,03,08,09,15,16,17,36,37,45,46,55,56
Address 01 -------------------------------------------------------
Controller: 038 906 019 JT
Component: G000SG 1572
Coding: 00003
Shop #: WSC 63351
WAUZZZ8E23A113509 AUZ6Z0B0164276
0 Faults Found:
Address 03 -------------------------------------------------------
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04255
Shop #: WSC 06435
0 Faults Found:
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 Q
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
0 Faults Found:
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul KAN 0305
Coding: 00104
Shop #: WSC 63351
0 Faults Found:
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 00042
Shop #: WSC 63351
0 Faults Found:
Address 17 -------------------------------------------------------
Controller: 8E0 920 930 R
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 01000
Shop #: WSC 19411
1 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
49-10 - No Communications - Intermittent
Address 37 -------------------------------------------------------
Controller: 8E0 035 192 B
Component: RNS 4.2 H06 BNO 0140
0 Faults Found:
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AT
Component: Komfortgerát T23 1210
Coding: 06976
Shop #: WSC 63351
0 Faults Found:
Address 56 -------------------------------------------------------
Component: Radio BNO 0001
Coding: 00017
Shop #: WSC 31984
0 Faults Found:
End -------------------------------------------------------
Noen som har noen tips på hva som kan være feilen?
Mistenker antenna..
Når jeg sjekker på navi'n, så står det at den oppdager f.eks 30 sattelitter, men mottar fra 0.. : klø :
På forhånd takk..
Du har feilkode i instrumentpanelet ditt. På navigasjonen er det ingen feilkoder lagret.
Prøv og slett feilkoden på instrumentet og se om den kommer tilbake.
Mistenker antenna..
På forhånd takk..
Stemmer som Tarjei sier at feilen fra vag-com scannen din er lagret på instrumentet, har nok desverre ingenting med problemet ditt med mottak av satelitter å gjøre. Du har nok en defekt navigasjonsantenne (vanninntrengning), ikke et helt uvanlig problem.
Ok..
Men hva er den feilen jeg har fått opp for noe da da?
Ok..
Feil i kommunikasjonen mellom instrumentet og navigasjon / CD spiller.
F**n.. Håper dette bare er en forbigående feil.. dritt at sånne feil skal komme på en bil som bare er 3-4 år gammel..
Det er for dårlig..
Noen som vet hva som kan forårsake sånne feil?
Mvh Geir
Det er for dårlig..
Mvh Geir
Ca 200 ting :) Dårlig kontakt, ledningsbrudd, dårlige loddinger osv.
Det kan også være at du har tatt ut enten instrumentet eller navigasjonen din uten å slette feilkoden.
Ikke noe jeg ville brydd meg så mye om egentlig. Som jeg sa til deg på PM: se også om den kommer tilbake.
Vi kan se på dette også når du er her dersom feilen kommer tilbake.
Coding: 01000
Shop #: WSC 19411
1 Faults Found:
Denne gir vel svar ang denne feilmeldingen ihvertfall:
